SOHC.co.uk Forums => CB350/400 => Topic started by: Clouddancer on November 25, 2022, 07:58:12 AM
this is rare chance to buy an fully refurbish HONDA CB 400 Four Motor.
Everything was stripped down/ Inspect and replaced if necessary
Target : High Torque Motor.
Seller speaks Englisch
Pictures on Request please contact me by Privat Mail
Verk. Grundüberholten CB 400 Four Motor
Motor mit VIELEN Orig. HONDA Teilen neu aufgebaut.
Drehmoment starker Tourensportler durch Orig. YOSHIMURA 54,5 mm / 466ccm Kolbensatz
Neuteile :
54,5 mm /466ccm YOSHIMURA Kolbensatz
Zyl. / Zyl.Kopf plan geschliffen
Zyl. Kopf überarbeitet
VITON Ventilschaftdichtungen ( DYNOMEN)
Ansauggummis
Steuer - / Primärkette
Spann - / Führungsschiene Steuerk.
Std. Serien Nockenwelle mit Gradscheibe eingestellt
Gunmmis Primärantrieb
Anlasser Freilauf
Kupplungsbeläge und Verstärkte Federn
Dämpfergummis im Kupplungskorb
Kontaktlose Zündung
Zündkerzen
Zündungsdeckel
HONDA Emblem Lichtmasch.
alle Wellendichtringe
V2a Schrauben
neu lackiert mit HARTJE 2K Lack
Not a real 460 Yoshi then, only the big n bore kit in an overhauled engine, unless a lot is lost in translation.
Hello ka-ja and Hello to each other!
Please read my Offer Carefully, Translation below ( from Translation Programm....)
If some of you looking for an highly prepared CB 400 F / 466 YOSHIMURA Motor please
wait for 5/10 days .Motor is in Progress ......
Selling completely overhauled CB 400 Four engine
Engine rebuilt with MANY original HONDA parts.
Torque strong touring athletes with original YOSHIMURA 54.5 mm / 466cc piston set
new parts :
54.5mm /466cc YOSHIMURA Piston Kit
cyl. / Cylinder head ground flat
cyl. revised head
VITON valve stem seals (DYNOMEN)
intake rubbers
Control - / primary chain
Clamping / guide rail control c.
Std stock camshaft adjusted with degree wheel
Rubbers prime mover
Starter Freewheel ,new Internal Parts
Clutch linings and reinforced springs
Damping rubbers in the clutch basket
Contactless ignition
spark plugs
ignition cover
HONDA emblem alternator.
all shaft seals
V2a screws
repainted with HARTJE 2K paint ( Orig. HONDA Engine Colour ,Fuel /Heat Resistant )
What is HARTJE 2K paint ? Any links to supplier/specification please?
Hello TOKO_JO,
look at www.motorradlack.de
Orig. HONDA Engine Colour : Grausilber ( greysilver ) ready for Spray incl Hardener ' 21098
Orig. HONDA ENGINE Colour Grysilver ( Rattelcan ) # 88-0008-5
If more Details needed please let me know.....
EVERY HONDA ; SUZUKI; YAMAHA Colour ist availabel !!!HIGH QUALITY !!
You'd think we so many different colours of paint on their site they'd have added a search function. Stupid.
Any info on pricing, pictures?
Thanks,
Kristijan
Hello KIKI.O send you an Privat Mail......
