Other Stuff => Desperately Seeking!! => Topic started by: mickwinf on May 02, 2023, 12:17:35 PM
As title I need the flat bracket that mounts the clocks on the 500 as lazarus had a lashed up bracket fitted. It is the uk smaller instruments type. Also i might need a speedo if anyone has a spare.
I will have a look if i have spare, would you consider the us small clocks that are tilted a bit towards the rider?
Hi Bryan, the clocks I have are really bad, not sure if they will restore. I am not worried about being a mix of uk, usa or k0 k1 as long as it is Honda so see what you have.
I will try saturday, pm me your email and i will send pics
If Bryan doesn't come up with one, I have one. But needs a little fettling as the two threaded fittings look like they come out at slightly different angles. But now away for a week.
