SOHC.co.uk Forums => CB350/400 => Topic started by: Golfcarmad on April 23, 2020, 07:25:36 PM
Hi guys n gals,do anyone know of an alternative indicator relay to the DS £30 part?
A12v halfords part
Mine is the round one with 3 pins.
You can use a 2 pin if you leave off the earth (green)
There's cheaper shops than Halfrauds. Use a 2 pin, leave the green wire off.
Thanks-will give it a try.
Just being generic
Ive got a used original relay, which i think works if you want it, £6 posted
[attachimg=1]
[attachimg=2]
I will take it thanks if you don't want it Golfcarmad
Please can I have it-sorry for delay.
Regards
Paul
Hi Max,I wrote a reply with details you asked for,it will not send as no email address for you.
Mine is pauliskelly@hotmail.com
Thanks again your a star
saw this
https://www.motorcycleproducts.co.uk/12v-2-pin-round-indicator-relay/1/006111?bike=8945
Thanks,I have tried several now-no difference-confusing.
Are you using led bulbs?
not Led.
Chinese indicators with 10w bulbs.
I even tried to old indicators that came with the bike-again no flash though I note they are 10w also
Indicators should always be 21watt
Interesting as manual says 18w.
Tomorrow I will rig up some 21w bulbs and see if that works.
Many thanks
Stay safe
Thanks everyone-it is bulb wattage.21w which don’t fit indicators I have unfortunately-work perfect-so flashing again.
Cheers please stay safe.
So fit led bulbs and a flasher to suit, at least you have two seperat repeaters
