SOHC.co.uk Forums => CB750 => Topic started by: Martin6 on April 11, 2023, 05:25:46 PM
I've hopefully got the carbs where they need to be, for the moment!
Rather than add to that topic, I thought a new one is in order!
I have some miscellaneous other minor issues to have a crack at and any words of wisom are very welcome:
- Neutral switch needs checking, remains dimly lit when in gear;
- I have a strange tramping sensation through the bars on some roads at speeds over 30mph. I'm hoping it is wheel balancing, as the red dot is not right on the tyre valve, and there is a 20g wheel weight close to the valve, which isn't where I'd expect it? However it may be front suspension. Standing, front brake on and pumping the bars, it moves up and down and seems damped, but is stiff. Will check which fork oil it has in there. What grade is recommended for a compliant ride?
- Difficult to find neutral, easy when rolling to a stop, but not when stationary;
- May be related; the clutch bite seems quite late in the lever outwards movement, but no clutch slip is evident when i open the throttle. Is this usual?
Front forks are not normaly "stiff" Honda originaly used engine oil but later used ATF.
Lot of debate about the dot on tyres but personaly seen them all over the place with no effect, could need wheel truing or balancing, Honda tolerance for true is 3mm side to side and vertically(mot says 4mm) Sounds like neutral switch is failing and the clutch needs adjusting as per manual.
The full Honda workshop manual is on this site for download either in alladins cave or Ashs dropbox
With regards to neutral switch - it can be also some unwanted connection of neutral switch wire to frame (ground). To check that disconnect wire from neutral switch, if control light is still on, look for wire issues, if not it is switch itself.
Thanks Bryan.
Yes, if the high bite point is not normal, I'll look to adjust the clutch. I have the downloaded manual and have the Haynes (not too impressed with the Haynes though).
I'll also be changing the front tyre, which will be a good time to check how true the wheel is. 3mm seems quite a lot. Looks like the forks may be the problem if they're not usually stiff. Mine are definitely stiff. The previous owner replaced one stanchion, the left, as it was bent. So I'm now suspicious of the right hand one. I'll check that with the wheel off.
When checking the wheel for true make sure you can easily see where the weld is as you will always get a "kick" in the rim at that point and drive yourself crazy trying to remove it.
You can easily get them closer than 3mm, that only the max allowed
I might be way out here but when I had a tramping sensation on my Suzuki 750 GS it was the chain & chain wheels causing the issue. To many wheelies by previous owner.
I could not afford to replace the sprockets & chain so I fitted a new chain only & cured it.
Ted, was that felt through the handlebars?
I'm going back 40 odd years but yes it was a really odd sensation like a thrumming that was felt up the frame into the handle bars. It was speed sensitive worst at 50 mph.
I didn't know a much about bikes back then - no internet - but a fellow biker said it sounded like a stretched chain causing the issue.
Checking wheel balance and alignment might be a better starting point.
Just a thought but how old are your tyres? Sounds front end related snd agree with Ted but if your tyre’s old they do deform and can produce a similar sensation.
When Maxxis first came out the fitments for the VFR’s and other touring bikes had an intermittent vibration that only manifested itself at a certain speed which turned out to be a mismould and all were recalled .
Check your balance is cool and wheel bearings. Any point of contact really, you’ll find the issue
You get tyre flat spots on cars that are only used in the summer so has it been stood for ages. I use some cheap wheels to stand the SL on over the winter. It takes a good 40 miles at 50 mph to spin out the flat spots otherwise
Could be.
Rear is new. Avon RR. I rebuilt that wheel, but checked it again today and all seems true.
Front is about 100 miles old, but has been on 4 years, i could have a flatspot from standing.
Aren't the dots normally the heavy point on the tyre and usually 180 deg from the valve ?
Fork oil, many go too heavy with this in my experience, partly promoting some level of hydraulic "locking" in response to pattering Road surface. Effectively tge fork doesn't want to move at the linear rate the road irregularities are kicking the suspension up at and causing a little "bucking" feel to come through the front end.
Reality check though, is to assess current level of existing oil, too high will give less fork response than design intention.
Try using Motul 2.5 grade viscosity fork oil at correct level /quantity to see if it's effective in getting the response you want. It's a very good oil anyway and won't give problem, but some may prefer 5 viscosity.
Healthy clutch engagement is ok fairly far out as it makes sure the clutch fully disengages and promotes no clunk when going to first gear when stationery.
If the clutch is used hard on these, heating up the clutch pack moves the lift mech thrust away from the operating mech, and you'll feel the bite point move in toward the bars in this case. You do have to get them pretty hot to see that, but it doesn't usually make it slip with this arrangement.
Yellow dots, if you have them, are the lightest point on the tyre. To be mounted where the valve is. Red dots signify the flattest point of the tyre. I don't know why, but I always mount them where the valve is, perhaps on the assumption 'flat' = lighter. The odd thing is my front also had a 20g weight at the valve area.
I did a slightly longer ride today, gaining more confidence! The harsh ride becomes evident above 40mph, in any gear. It smooths out over 65mph.
The K6 has a later design of fork. It takes 155cc to 165cc of oil, about 50cc less than the original forks. It's not immediately obvious in the Honda or Haynes manuals. I guess it is possible previous maintenance might have been to the original fork oil quantity specified. Would too much fork oil give harsh riding symptoms like this?
I re-checked the rear wheel (I recently re-built) and it still seems true and spokes tensioned. Chain seems OK. It spins nicely without any lateral play in the bearings and the rear brake is smooth. So i think the used, replacement hub is fine. The chain is not in the first flush of youth, but doesn't particularly lift off the rear sprocket. Tension is there-abouts. So, in my mind, I've ruled out rear wheel and chain.
I do notice, when I spin the wheel, a ticking sound from the front sprocket area. A quiet rhythmic ticking, like the old Sturmey Archer bicycle gears, when they freewheel. The sprocket is tight, it's not particularly worn and the chain runs smoothly on it. The shaft the front sprocket is on has a small amount of lateral movement, 1-2mm maybe. The ticking is coming from within the engine cover (inside the gearbox?). Is this all normal? If so, I'll concentrate on the front forks.
Thanks, Martin
Ticking sound then when the wheels spun but the drive cover is off?
I'm a little concerned about the lateral movement on the final driven shaft. In theory there shouldn't be any, the shaft is pressed onto the large sprocket bearing behind the oil seal there, that's normally locked into the crankcase with what's called a setring, this locates in a groove inside the crankcase and so in theory the shaft isn't able to move laterally. Are you pulling the shaft or the sprocket?
The front sprocket can cause some problems if you buy cheap, it's essentially a castellated hole that slides onto the drive shaft, this is then locked in place by a fixing plate, that locates, spins 90 degrees and bolts onto the sprocket. If the sprocket is a cheap make it's been known for the castellations to deform, so that the sprocket moves on the shaft forwards and backwards, better make sprockets use harder metal and they tend not to do this for much much longer, by the time they do the teeth are buggered anyway. Check the fixing plate for wear marks, if that's worn it will allow the sprocket some lateral movement, the sprocket shouldn't be rigid, it has to have a small amount of freeplay to adjust to the drive chain angle as it lashes about but it shouldn't be a great deal. Is the front sprocket maker marked?
You're right. It is the sprocket moving laterally on the shaft. The shaft is solid, no lateral play. The sprocket has no rotating play on the shaft, when attempted by hand. I didn't remove the retainer that's bolted into the sprocket. I couldn't see any manufacturer stampings. Does that all seem right?
Getting quicker at taking the cover off!
You may not get the movement on the sprocket with the chain still attached, best to check this with it off the sprocket. Also remove the fixing plate and check that and also check the sprocket again then, it's a bind but it's the best way to check for problems. Plus you an spin the drive shaft with the chain off and see if the ticking sound is coming from that, could be the bearing making the sound.
Thanks Oddjob. Makes sense. I've not yet taken it apart. From what I can hear, it could be a bearing noise. I will have a better look tomorrow, I was wary of damaging the locking tabs on the fixing plate.
If it is the bearing, there's a seal behind the sprocket and then the bearing. Is this the "final driven shaft" (fig. 5.18 on pg 70 of the factory manual)? It looks like it would need to have the engine case open to replace that bearing?
Yeah it's a casing split to replace that one AFAIK, not the expert on the 750 as some members on here, didn't like them back in the day, still don't like them, I avoided working on them whenever possible. Not saying the 750 is a bad bike, far from it but I thought the 500 was a far superior bike and I concentrated on that model in preference.
For what it’s worth definately worth splitting and whilst in there checking everything all cogs, dogs, bearings etc. Also phobia about lateral movement in that fifth gear, which in my case I had to shim to take out about >1.5mm, doesn’t sound a lot but when you’ve only got 3mm of insertion 2/3 into 5 cog it’s too much as I found out to my cost.
Thanks. I've removed the chain and the front sprocket rotates freelywith no noise. I've removed the sprocket and confirmed there is no lateral movement in the final drive shaft. The shaft looks quite clean and sharp machined castellated edges.
So, I am relieved. I can’t afford a strip down at the moment. I want a season to ride the bike, find any more issues and then, maybe next year is the renovation year, if needed.
A picture of the front sprocket and retaining plate is attached. I will replace these, new chain and tab washer. Rear sprocket looks fine.
On a 1976 made K6, is it a 520 or 530 chain, I think it's a 520? 102 links? Can't find it in the Honda manual.
That sprocket is definately worn out, put up a pic of the rear wheel sprocket before you buy any thing as a kit can be cheaper
I agree with Bryan that front sprocket shows quite a bit of wear - in my head they become more spikey with mileage. It's a little used technical term I've learnt.
Picture attached. Where would you recommend for decent quality chain and sprocket sets?
It may be the pic and resolution but the teeth dont look even to me so i would change both, as to where to buy thats a minefieldi prefer not to give advice on because a fantastic chain for a steady rider may snap with somebody else, i would stick to DID or maybe RK.
Visualy looks like 530 to me which is the old British 5/8x3/8 so try measuring between pins and width of roller, i also thought all the 620 front sprockets were held on with a central bolt but its been over 40yrs since i did one so no guarantee.
You could try looking up the parts for your bike at cmsnl it should tell you there.
Adition to above i have bought from www.motorcycleproducts.co.uk (incuding the lock plate)
Further to that you need to trawl through all the pages as you will find the same things at different prices on different pages, also do oil and ail filters, plugs,etc
Thanks Bryan. I called Jason the Chainman. He did my excCommando chain. It is a 530, he got me to measure the old one, to confirm. Now on order.
I'll search online to get the sprockets.
You will find them on the site i gave you with several variations of tooth count, and the lockplate if you want it
Thanks Bryan, I've given them a try. 👍
Glad you managed to navigate that site, not the best in the world
Yep, if there's a logic to how they present the products, it escaped me. Good to support a range of suppliers. I hope the sprockets are good and tough :)
They had some other stuff I was tempted with, but I'm holding off cosmetic upgrades this year. That's a too long list! I want to try to get it reliable before I go down that rabbit hole.
Martin
I had this problem with a 750 K6 that I owned some years ago and, as ted has said in my case it was caused by the fitment of a wider (O ring) chain that a previous owner had fitted. A replacement chain and sprockets cured matters, however not before numerous attempts at wheel balancing etc.
The effect when riding with the wider chain was certainly odd, as though something was speeding up and slowing down in waves, felt through the whole bike.
Mine feels more like the front wheel is trampingat speeds of 40 to 60mph. Not a violent feeling, jbut noticeable. So, may not be the chain and sprockets. But good to refresh those anyway. I'll be doing the fork oil as well and see if it all helps.
Final thoughts if it's definitely a front wheel area issue flags up the following ideas.
Is the wheel rim & tyre completely round - try some visual checks with the front end jacked up - rotate wheel check against best means you have of looking for ovality.
Fork oil change you already have in mind.
I've no experience of effects of wheel bearing wear aside from noise - the front brake will make wear difficult to check.
Probably stating the obvious so just trying to give you my thoughts.
Took it for a run in the sunshine. New chain and sprockets are fine. I also re-checked the rear wheel, which looks true enough and I re-seated the new back tyre and confirmed wheel balance. There's still a wrong feeling, which I'm convinced now can only be from the front end. It's possible too heavy a firk oil. That's the feeling. I'll have a look at that on Wednesday. I have some ATF I can use. I'll check the front wheel is true as well.
Is there any change a fork, or forks, may be bent Martin?
Julie, I've wondered, but I don't think so. They seem to move smoothly, without any sticking when I pump them.
I decided to change the fork oil this evening:
The left fork had 200ml of oil and it was a little thicker than the 5W30 fork oil I've bought. It had some dark residue in the oil. The right had 160ml of ATF, which was clean. According to the >K4 supplement in the Honda manual, the correct amount for a K6 would be 155-165ml. 5w30, or ATF. So I put 160ml in both. Difficult to be sure, but I feel it is now slightly easier to pump the forks. At 200ml, perhaps the left fork was hydro-locking on poorer surfaces? On the other hand, 40ml isn’t much, so probably not.
I have a longer ride planned tomorrow, to go and see a friend's dismantled Suzuki GT185. 30 miles each way. A good chance to see if the oil change has made any difference.
40mm on 160mm is 25% so its a big increase
Interesting to hear outcome with forks, hopefully positive.
As Bryan noted, its quite a big shift in air volume as it changes much more in ratio through the travel when you start with less space above the oil. Effectively it's making a more concentrated ramp up in spring rate from the resulting air chamber being decreased in size.
One of the reasons I favour a dedicated fork oil like Motul is because it can be more optimum in regard to stiction which is prominent in sliding bearings. ATF is a good balance, but very tighly controlled for it's finite friction properties to ensure consistency in the auto transmission clutch packs, has good anti foam properties too. Dedicated fork oils don't need that friction consideration and generally outperform in that regard. It does make even an old fork perform the best I've found when used.
Sadly, no improvement today. Definitely feels like the suspension, as it is not rhythmic, more a disruptive patter, on uneven surfaces. Guess I'll have to remove the forks and check them.
Also, the throttle has started hanging open again. I think that's the damage to the slide/bore on carb no.4. This bike is fighting me. :)
Any chance the tyre isn't fully on the rim all the way around.
Good prompt. I'll check the wheel and tyre first.
How are you all lifting the front end off the ground? I don't have a bike lift. At the moment, I'm putting a block of wood on a car hydraulic jack, bike on centre stand and lifting with the jack under the sump. Is the sump strong enough? It feels a bit hairy and I'm unable to strap the bike to anything. On my Norton I can easily weigh the back of the bike down, which lifts the front just clear of the ground. The C of G on the Honda doesn't allow that.
If you’re struggling throw a ratchet strap over the back with the centre stand whilst its on a block of wood and screw either end of the strap to the floor with a couple of big washers so they don’t pull through. You can lock the back down as far as you like.
Bit of a cowboy ‘get out of jail free’ card but it works
I got the missus to sit on the back of the bike whilst on the main stand. I measured the gap between the bottom tubes and the floor, 2 pieces of wood screwed together to form a letter H with the brace close to the floor so it clears the exhaust headers. Now she sits on the bike, I push the H underneath and it sits like that no problem. Scrap wood can be used as well. I had some offcuts of 3x2 and found them ideal.
Didn’t have any off cuts suitable at the time
I wasn't happy with the fork action (picked up all the little undulations) on my 500 and following asking about suggested improvement, Nigel (K-K6) suggested a thinner Motul fully synthetic 2.5w fork oil and there a great marked improvement in normal riding - bearing in mind I'm not a footrest scraper anymore!
Thanks all. I thought 5W30 would be light enough. It seemed lighter than the ATF I have. I'll give the 2.5 a go if I rule out everything else.
I would appreciate some advice on the top steering bearings. It swings fine, left to right. Just wonder if the top housing in the photo is correct. It has a 6mm recessed section showing below the bearing cap. It looks odd, is that the way it is meant to look? Can't see a photo in the manual.
I'm still working out the safest way to lift the front wheel off the ground!
In the meantime I've checked the carbs again. Two of them were pretty stiff and scoring the slide cylinder. I bit the bullet and worked on the scuffed areas with emery cloth. Required a few attempts, but now they slide reasonably smoothly. Be interesting to see if I've ruined the vacuum. No choice really, the throttle was sticking open. :(
Although I have a bike ramp I use one of these on the ramp.
Other makes & prices are available.
.https://www.ebay.co.uk/itm/203603502986
Ted, you're costing me money again! ;D
I like that solution. Wide enough to give some stability. Ordered.
I did think about carving frame shaped grooves in a 4'x2', but it would still be unstable on my jack.
Another member here posted a picture on an early post of mine so I bought one. Great bit of kit.
The listing photo is a bit misleading as it shows a bike with both wheels off the ground - that looks iffy to me - I strap the rear wheel down whilst on the center stand then use the scissor jack.
I warmed the bike up and adjusted the air screws. It seems to run best on 1/4 to 3/4 out. 1/4 on the two carbs I had to fettle, 3/4 on the other two. So it seems there is a reduction in air seal, but they rev up fine and drop back to idle swiftly. The idle was stable at 1200rpm, albeit still with a bit of chain noise. I think I've got away with it on the carbs.
Front wheel check will be at the weekend, after delivery of my new bike jack. I noticed some muck in the left hand fork oil, when I drained it. I'm wondering if there may just be an accumulation of crud that side, which affects the damping action? Has anyone ever flushed a fork out to clean it, without dismantling it, is that possible?
👍 Martin
Just take them apart, it's only one bolt at the bottom to undo to get them apart,you've undone everything else so that's all that holds them together. Just make sure that you loosen the bottom bolt when the forks are on the bike with the tops on to stop the internals spinning on the holder on the inside, they should just pull apart then. It's a dead easyprocess and at least you'll be a
ble to get all the crap out properly.
Is there enough room to slide the innards out from the bottom, without taking the fork off the yoke?
Undo that bottom bolt and just pull the lower off the stantion that will beleft in the forks. You willneed to set the air gap on reassembly or the oil amount so it might be easier just to take them out the yolks its far easier. I would.
Don't forget to renew the copper washer on the lower socket bolt.
If you remove the forks entirely, loosen off the bottom bolt first, whilst the fork tubes are firmly clamped by the yokes, same for the top nut, loosen off or you'll struggle getting it loose afterwards.
OK, thanks.
Re the tramping - Over tightened head stock bearing?
Thanks for the suggestion. I have checked that. It was over-tightened, which affected low speed turns, but that doesn't seem to be the issue. Unless the bearings are past it. However, now loosened off a touch, and front end off the ground, the steering moves from side to side without notchiness.
I am very puzzled by this. I even suspected a slight weave and wobble at the front. I re-seated the tyre, then replaced it. The wheel is true and so is the new tyre.
I still have an irregular lumpiness through the bars. Not vibration. It's like I'm constantly running over compacted mud, until I get to 55/60mph. It doesn't seem related to engine revs.
I'm guessing the bike originally had plain bearings so they might be suffering from water ingress issues?
If the bearings were ever notchy they'll still be notchy but as you've loosened them off the whole of the front end will now be moving instead. Fit taper rollers is my advice.
The Hondas these days have the headstock bearings pre-tensioned when you fit them, torque the headstock adjuster ring down to 18lbs, move the headstock a few times to seat the bearings, release the pressure then re-torque to 18lbs, you then fit the top yoke and get a spring balance and hook it to the top yoke, it should take approx 2.2-3.3 ftlbs to get the top yoke to move from central, by hand this feels quite stiff if I'm honest but when the forks/wheel goes in the bars move quite freely. Most people think it's too tight and slacken off the headstock bearings but that then leaves them too loose when everything is fitted.
Pyramid parts for some decent branded kits at a sensible price if you go for taper rollers I fitted them to my 500.
Depends Ted on who's bearings are in the kit, far too many with cheap chinese ones. If they are Toyo, NTN, Natchi or SBK they are good bearings.
You also need a kit with the spacer included.
Somewhere there is a thread with all the info needed, including bearing sizes.
Mine were NTN iirc I did post when I bought a kit for my 400. They also provide a better seal attached to a shim.
I shimmed mine to fit leaving sufficient top thread on my 500. The 400 has only half a kit from a different supplier I will remedy that in the future.
I want to keep the 400 as a runner until the 500 is completed - then I will return to tweaking a few bits on the 400 before I sell her or hit my expiry date - I was 75 at the weekend. lol
NTN are very good bearings Ted, good kit that one. Allballs kits are made in China, I'd rather have notchy bearings TBH.
You don’t look a day over 73 Ted
You smooth talker Roo - you've still got it Babes. 8) 8) 8)
If there’s enough ibuprofen in this world I hope to be still tinkering and riding at your age Ted.😁😁
Brufen is bad for the waistline mate, i use co codamol!
😳😳 I’m lucky! That’s one thing I haven’t had to be concerned about. Co codamol? Haven’t tried it.
Ibuprofen like most medications can have side effects - it's hard on your liver & kidneys if taken regularly as well as it's well known possible effects on your stomach. I believe it is not recommended if you are on heart medication.
Greatest help to get me riding my bike is nice warm weather - the sunshine lifts my mood plus lubricates my joints somehow.
Ibruprofen can cause ulcers hence the only with food so larger waistline.
Co codamol is a mix of codine and paracecamol, normal ratio 8/500, i have been known to use 27/500!
It’s like ‘Painkillers Anonymous’ on here today!
🤣🤣 analgesics is a major part of us more mature riders.
Oh for me it's Betta Blockers , Calcium Channel Whatsits & Protein Pump Inhibitors plus another that made me sprout a pair of decent Man Boobs not to mention the other three.🤫🤫🤫
More like unanimous Roo!
We’re a right bunch of creaky old buggers, love it
🤣🤣🤣 if it wasn’t serious we could laugh! Maybe we need another section on this forum? Nooooo 🤭🤭
Can you recommend a taper bearings set? Are they simple to fit, without any machining and decent instructions?
Thanks.
I have used https://pyramid-parts.com/
Good quality make bearings at a sensible price - I would measure the height of your old bottom bearing plus any shims then check against the bottom bearing in the kit use the bottom seal & any shims in the kit to ensure you get the bottom height correct.
