SOHC.co.uk Forums => CB350/400 => Topic started by: Boggieman on October 01, 2012, 03:43:40 PM
Hi All,
The throttle on my 400/4 is really stiff. Just wondered if this was a known issue as they get older.
The twistgrip itself is not the issue, it's a new one, and the cable has a non-restricted route. It seems to be the spring on the top of the carb's, can these be lubed, or changed if necc'?
Thanks for any suggestions.
Ian
Hi I an you could try a bit of wd40 or similar on the carb linkages might help get things moving freely again ;) cheers Mick.
If the cable has been "oiled" that could be your problem as Honda cables are lined and they swell and stick with lube
Hi uys
Thanks for that.
The cable has not been oiled, it is as is when it was new (if that makes sense).
Ian
probably just old and knackered then, like me
Bryanj.
Made me laugh are you as old as me?
Bitsa
Sorry about the last response(between old gits) as for stiff throttle disconnect the spring is all easy to operate?
If so you know what your problem is.If still stiff its the linkage corroded.
Bitsa
Sorry boys i beat him by a couple of years!!!
Thanks for the replies, made me chuckle.
I'll have a rummage round with the spring assembly over the weekend to see how if there is anything that can be done.
Ta again
Ian
Glad to help, when you get this old mostly all you get is laughter!
At this age you'll find most things become stiff. :)
Lester,
Not all things !!!!!!!!!!!!!!
Good Giggle though
Bitsa
Bitsa, thats what the 36 year old wife is for!!
I am ever hopefull of finding one.
Good thing you can still get best bitter.
Bitsa
