SOHC.co.uk Forums => CB500/550 => Topic started by: Ewan 500 K1 on September 26, 2013, 12:15:47 AM
sure I'd replied to this last night...... :-X
I've two sets .
First set, OEM .. distance between centres of mounting holes = 320mm
Second set, aftermarket ... distance between centres of mounting holes = 315mm
Dealers generally uote them as 13 inches or 325mm .. but dont specify between where and where.
For a definitive you could try Steve at http://www.bike-revival.co.uk/exp.html. He's easy enough to yak to on the phone
From aged memory the 750 originals were about 1 inch longer than the 500 but Girling replacements were all the same
