SOHC.co.uk Forums => CB500/550 => Topic started by: Rumpelkrankshaft on January 05, 2015, 06:52:22 PM
Title: Ignition dilemma
Post by: Rumpelkrankshaft on January 05, 2015, 06:52:22 PM
Following the sudden and complete demise of the electronic ignition system on the 550/4 I am thinking of refitting the original system. I need to replace both  of the point asemblies and the capacitors. I can get Honda genuine points but they are five times more expensive than aftermarket items and Honda capacitors aren't available. What's the Forum opinion on this-is the genuine option worth the extra cash bearing in mind that the capacitors will have to be aftermarket? For less than twice the cost of the Honda option I could fit a new electronic system. Over to you and Happy New Year to you all.
Title: Re: Ignition dilemma
Post by: Bitsa (Ralph Wright - RIP) on January 05, 2015, 06:56:30 PM
If it were me buy a whole points plate off ebay maybe and fit honda points.Capictors should not be a problem but have heard and read of lots of problems with various pattern points
Bitsa
Post by: Trigger on January 05, 2015, 06:59:24 PM
I love the old points system but, like a lot of parts these day are getting crap and even ones that come in Honda bags. I personally would go for the electronic system.
Post by: matthewmosse on January 05, 2015, 08:02:32 PM
When I first had my honda 500/4 I never needed to touch the points for about 150,000 miles or something quite rediculas. When they started going wrong I replaced the whole points plate with genuine Honda as at the time that wasn't that expensive. Never got it running that well with the replacement setup, even using a timing light ( Draper, fraid the stobe light might have been pretty crap and part of the problem) anyhow I replaced with a boyer system, but by then had changed a few other things and was getting carb issues so cannot comment on the reliability of the boyer system though their reputation is pretty solid. I can say 550k3 carbs whilst offering great economy were a swine for stale fuel messing them up - mine were anyway.
Post by: Bitsa (Ralph Wright - RIP) on January 05, 2015, 08:02:43 PM
Trig
You really rate them?What do they cost these days mate? :D
Bitsa
Post by: JamesH on January 05, 2015, 08:44:23 PM
I've used the Pamco system on a few 750's now - have to say I really like it...
Post by: Green1 on January 05, 2015, 08:52:18 PM
Whats wrong with points they last forever in the 750
Mick
Post by: Johnwebley on January 05, 2015, 08:54:11 PM
I have used Boyer since the late 70's,fit and forget,
 just us a strobe to set it at around 4,500 rpm
Post by: Norniron on January 05, 2015, 09:08:55 PM
Wot about hondamans ignition system off our sister sohc usa site.
Ive read good reports about it
Post by: Trigger on January 05, 2015, 09:09:44 PM
This still needs the points in place.
Post by: Erling on January 06, 2015, 09:23:03 AM
The Hondamans ignition poins is said not to carry high tension current. Thus lasting for ever!
Post by: fisjon on January 06, 2015, 11:53:41 AM
The Honda electronic ignition system on my CB650 was futile so I ripped the whole thing out and replaced it with Boyer. If you see the power of the spark that the Boyer system supplies (it's like an arc welder), you won't want to use anything else.
Post by: florence on January 06, 2015, 01:07:22 PM
I have to favour points, I've always used them and had very few problems.
However, the quality of replacement points is poor these days so if you can find proper ones at reasonable price..........
Electronic ignition is pure science fiction  ;D and when it fails it usually fails catastrophically meaning a roadside repair is out of the question.
Post by: Johnwebley on January 06, 2015, 04:29:33 PM
the last electrical failure I had ,a soldered lead came off the rear off the ignition switch,quick get me home dodge,a sharp small safety pin
through the 2 wires to make a circuit,and home to affect repairs,
but,a word of advice,I you fit Electronic ignition,its always worth getting new plug caps,as they deteriorate over time and use,
thats what causes shorting issues in the wet ,also can affect the quality of the spark,
Post by: Bitsa (Ralph Wright - RIP) on January 06, 2015, 07:36:32 PM
Same for me Florence buy decent ones and no problem.Bet all the sandcast and koers owners have gone electronic though yeah in yer dreams
Bitsa
Post by: Rumpelkrankshaft on January 07, 2015, 02:55:11 PM
Interesting mix of replies,points lead by a short head. Now I have to make a decision! Will advise outcome in due course,thank you all for your replies.
Post by: Bryanj on January 07, 2015, 04:17:33 PM
If you are going to do a lot of miles go electronic, if like most on here less than 1500 per anum stay points but maybe with Hondamans kit
Post by: peterengland on January 07, 2015, 04:21:46 PM
I get the geniune Honda popint from DS and have had no problem with them, only the bloody cork gasket that seems to become misshapen easily.
Post by: Bitsa (Ralph Wright - RIP) on January 07, 2015, 06:44:05 PM
Agreed with the cork bit,as mine are only ridden in the sun done away with it got a shed load of em somewhere
Bitsa
Post by: Rumpelkrankshaft on January 08, 2015, 06:44:59 PM
In full agreement re the gasket
Post by: fisjon on January 13, 2015, 07:17:11 PM
Boyer gives smoother tick-over, better acceleration, better mpg, better performance. END OF!
All due to a huge big fat bright blue spark always fired a the right time. The Honda points system is like a wet fart (a tiny little yellow putt) compared to the Boyer. If you haven't seen a Boyer spark to compare, you can't make a comparison. No contest. Those of you stating that the points system is better are just harking back to the 70's for the hell of it. Wise up guys. Oh, and maintenance free!
Post by: Lobo on January 14, 2015, 02:03:05 AM
.... just be aware, any electronic sys you fit will likely need a relay including into the circuit: a fatter spark doesn't come for free. The fatter spark will draw a higher current through the system, and my Newtronic H04 certainly recommended this as the Kill Switch was not designed to carry the increased load.
That said, not a big job to include... if you go this route will happily supply a fag-packet wiring diagram.
Simon
Post by: Norniron on January 14, 2015, 07:39:33 AM
Simon
Please do Simon.i do recall u mentioning this in a previous post but I can't find it.
Title: Lobo
Post by: Lobo on January 14, 2015, 03:10:50 PM
Hi Norniron,
I'm having 2nd thoughts abouts my statement "Newtronic certainly recommended..." as I've since googled those instructions... and it doesn't! That said I do remember the actual fitting instructions came with an 'addendum slip'.... and it may have been there. Forgive me! Regardless; I have indeed read on other forums, fitting a relay is no bad thing due 40 yr old kill switches / increased current draw on these electronic ignitions... and this is what I have personally done.
Whether you do / don't is up to you, and it may well indeed be recommended by your unit. Bed time where I am... tomorrow will post the simple wiring diag if you're still interested.
The post you were looking for might have been Bodds,
Cheers,
Simon.
http://www.sohc.co.uk/index.php/topic,6955.msg39454.html#msg39454
Post by: Norniron on January 14, 2015, 08:37:08 PM
Yea simon,im still interested.dont want to be left broken down with a melted kill switch.
I have a dyna ignition on the 400 and im gonna put on the dyna coils soon.
Title: Lobo
Post by: Lobo on January 15, 2015, 03:23:14 AM
Hi Norniron,
Agreed... if you're going to fit higher spec coils you probably do need to 'offload' the poor old Kill Switch a bit.
A couple of comments, having slept a bit.
(1) some electronic ignitions (eg DSS offering) will use a 'full time' live supply (eg rear brake light black lead); and in this case will not be drawing any extra current through the kill switch. In other words, such systems do not really need extra relays.
(2) other electronic systems, such as my Newtronic, specifically state that their unit must NOT be permanently live, as damage would result.... much as leaving the coils ON when the bike's not running. Newtronic thus specify their unit is to be powered through the kill switch... I guess whether you then add in a relay to offload the kill switch is up to you. (I have)
(3) If you're going to be replacing the coils with non-OEM high Perf units.... a relay is almost certainly advised.
(4) Electronic ignitions have a minimum voltage requirement, and below this 'will not play ball'. I can't remember, but it is normally specified, and around 9v as I recall. A relay suffers the same problem, ie requires a minimum voltage to operate, so don't go choosing one with an 11v threshold! (I think they're all arounds 9v to be honest).
Point is though, if the battery is seriously depleted you're not going anywhere.... even bump starting will not help. On a poorly bike, using the starter motor may drop the voltage below critical too..
(5) in my diagram connections 86/85 can be reversed, and connections 30/87 can be reversed... it doesn't matter.
I've included a typical relay link.... tho' they're avail all over, Maplins, Halfords etc... if wanting to get technical (yawn) you're after a 12vDC / 5A (minimum) SP/ST/NO. (single pole, single throw, normally open). It'll have 4 connections...
Hope this helps,
Simon
http://www.autoelectricsupplies.co.uk/product/169/category/36
Post by: matthewmosse on January 15, 2015, 03:57:55 PM
I don't think my boyer system ( stock coils but replaces points ) reccomended a relay. One thing I would say about relay useage. My Bmw twins were both fully loaded with relays to protect the switchgear, especially the ex police bmw. At 90,000 miles for the ex plod bike and about 75,000 for the other the switchgear was in pretty poor shape. No end of electrical issues. Swichgear itself on the bmw machines was by tec, same as my 500/4 I belive? Anyhow the point I am comming to is that my 500/4 completed double the milage of either of the bmw machines and all the switchgear has remained reliable, totally reliable. The bmw stuff had the benefits of relay protection and yet both the relays and switchgear were the cause of may hours fault finding and a couple of Aa recoveries when things like the headlights decided to play the no worky game when out on long ride outs. This inevitability means I think if you can get away with it, then avoid unnecessary complication. In short I think I would start by checking no relays are required with any electronic ignition. On my cb500/4 I have 2 ignition circuits, one being remotely controlled by the keyfob. Not only does this mean you can start the bike from the comfort of your own home and come out to  a ready warmed engine, but before now I have blown the bikes main fuse, and not had to stop or pull over, I was able to pull in the clutch, and restart using the remote. Also handy for scaring the living daylights out of passers by, when the bike apparently starts itself as they walk past.
Post by: Norniron on January 15, 2015, 08:52:27 PM
Thanks simon for your time trouble and knowledge.
Very much obliged
David
Post by: Trigger on January 15, 2015, 09:04:30 PM
Very much obliged
David
Are you learning about electrics mate ;)
Post by: Norniron on January 15, 2015, 09:05:52 PM
Very much obliged
David
Trying to trig
Post by: Trigger on January 15, 2015, 09:07:43 PM
Very much obliged
David
Trying to trig
Good, then you can teach me in plain Irish ;D
Post by: Bitsa (Ralph Wright - RIP) on January 15, 2015, 09:09:07 PM
I remember bowyer in the 70s like harley over rated and over priced nowt wrong with standard set up.
Bitsa
ps even now wont be converted so dont bother to
Post by: Norniron on January 15, 2015, 09:20:16 PM
Bitsa
ROGER
Post by: Lobo on January 15, 2015, 11:59:10 PM
Yea Matthew,
I'm honestly with you all the way on "keep it simple"; Honda did a great job. My personal failing is I enjoy electrics / like to tinker.... and so any excuse. (& anyways, 70's electrics is just like plumbing... without getting wet!)
In Norniron's case, he's fitting up rated coils... I don't know the spec but have read elsewhere that various aftermarket coils are somewhat more beefy / power hungry than OEM. There comes a limit as to how much current you should reasonably expect a switch designed to a lesser spec to pass... and so a relay becomes a necessary evil in such cases.
In the case of a breakdown attributed to a relay failure in this case.... a very simple roadside fix would be to disconnect #86 & #87 from the relay & then connect them together.... the kill switch will now feed both the coils & Electronic ignition directly.... ie we're back to the original wiring. Perhaps David, mark those two connections with dayglow or something & put a connector spade in the toolkit! (tho' modern relays rarely fail)
(or #30 to #87 would work... the ignition will now be permanently live... ie if the kill switch failed this would also be a get-you-home)
Simon.
Post by: fisjon on January 17, 2015, 03:19:39 PM
The Boyer system I fitted to the CB650 was a complete system, coils an all. Not one item of the Honda set up was retained. It cost £170 and was worth every penny. I could not believe the difference.
The engine started up instantly as you pushed the button, no delay.
The exhaust sounded crisper.
Throttle response was positive with no flat spots or hesitation.
Considering the CB650 came with electronic ignition as standard the difference between the two was a revelation.
It was like having an extra 100cc added to the bike.
I've used strobes and dwell meters to set up points/ignition but it doesn't matter how good you are you will not get the same performance improvements that will come with a full electronic system. If you take you time and put it in carefully you can then forget it, no maintenance required.
Don't be a dinosaur, go get a Boyer.
Post by: Bitsa (Ralph Wright - RIP) on January 17, 2015, 06:44:49 PM
Each to there own some do points no problem some DONT ;) ;)
Bitsa
Post by: Rumpelkrankshaft on January 25, 2015, 06:46:07 PM
Genuine Honda points obtained and fitted,also replaced capacitors. Fired up just great and runs fine. Thanks again to all who responded. Generated quite a lively debate but points won on points. I'll get my coat.............
Post by: Bitsa (Ralph Wright - RIP) on January 25, 2015, 06:51:02 PM
Well there you go rest my case ;D
Bitsa
Post by: LesterPiglet on January 25, 2015, 10:11:21 PM
Hello chaps. In a bit late.  I have the Hondaman unit (from US site)  in my bike and I would recommend it. Cheap as well as having a great warranty. I noticed how easy the bike started when I installed it.
Post by: Norniron on January 25, 2015, 10:40:33 PM
Yes les,i think i will order a few of these.only read good things about these,no bad
Post by: Trigger on January 25, 2015, 10:55:09 PM
I can not see the point in using the Hondaman system when you still have the points. If the backing plate warps it has to be replace for it to work but, i am still not sure if the points are worn out if the Hondaman system will still work. So it seems like the Hondaman system is just a boost to the points.
Post by: Bryanj on January 26, 2015, 07:40:43 AM
Trigger the Hondaman system drops the points voltage tp a negligible ammount so the contact surfaces dont arc or wear, yes the heel still wears but after initial bedding in that too is normally negligible
Post by: Trigger on January 26, 2015, 09:05:06 AM
Cheers Bryan, that is a bit clearer on how it works. I knew someone that had problems with his points and bought one thinking it would cure all this problems. It was still the same problem until he fitted a new plate and points. This is why i said that i could not see the point when it worked out a little expensive when you take into the Hondaman system and a new plate with points. When he could of fitted a Dyna cheaper.
Post by: matthewmosse on January 26, 2015, 09:19:56 AM
Thanks for the explanation Bryan. It has helped me understand a tiny bit more of the dark arts world of electricity. I must admitt when I ditched points for a boyer system it was to cure an intermittent problem that was probably for more to do with carbs. However I have yet to re visit the issue and apply my new theory and will probably not do so as I am in any case swapping parts as part of the rebuild to go slightly more original.
Post by: Bryanj on January 26, 2015, 04:35:46 PM
If you are old enough you may remember "Sparkrite" ignition systems for cars, i put one on an escort van and didn't touch the points in 4 tears
Post by: Bitsa (Ralph Wright - RIP) on January 26, 2015, 07:03:38 PM
Did you cry once a year Bryan? ;) ;)
Bitsa
Post by: JustcallmeMrT on January 26, 2015, 10:03:27 PM
I've been reading along here and trying to get my head around the electrics.  My coils are done and need to be replaced, so was considering a set of dyna coils - would these stronger coils impact the standard points system?  Does more current then run through the points, thus making the Hondaman setup a good idea?
Nothing like reading a few threads to feel ignorant again!  ☺
Post by: Norniron on January 26, 2015, 10:17:08 PM
Post by: Trigger on January 26, 2015, 10:30:19 PM
Is this the statement that Hondaman wrote  ;D
Post by: JustcallmeMrT on January 26, 2015, 10:32:54 PM
So out of my depth!
Post by: Bryanj on January 27, 2015, 08:10:41 AM
No Bitsa, as you well know after a 13 hour night shift my keyboard is dyslexic
Post by: Bitsa (Ralph Wright - RIP) on January 27, 2015, 09:08:10 AM
 ;D ;D ;D
Bitsa
Post by: SteveD CB500K0 on January 27, 2015, 09:40:46 AM
Can't be.
The whole point about high performance coils is that they offer a lower impedence and hence generate a higher current when active. The voltage in the secondary (HT leads in this case) is a function of the rate of change of the current (not the level of current itself).
When the points open, the current in the coils falls at a huge rate (1000's of Amps per second) and the large HT voltage is generated in the secondary.
Cutting the current back down to standard won't give you a fatter spark unless the secondary has more copper turns.
When the points are closed, the higher current flows through the coil. It doesn't generate anything at that stage - just burns power!
Steve (BSc Eng University of Sussex 1976-79)
I could do the differential calculus back then...
Post by: Nurse Julie on January 27, 2015, 09:56:48 AM
Oh my goodness. Electrics in the human body are soooooooo much simpler. Either they work or they don't !!!
Julie
MSc BSc(Hons) RGN
Post by: AshimotoK0 on January 27, 2015, 11:19:08 AM
One day I am going to reproduce a modern version of the CDI I designed and  made for my original 400/4 back in 1978 (whacked the standard coils with 400VDC switched by a thyristor from a capacitor (the cappy was a spare  from my Pye valve colour TV at the time!). Retained original points (Honda Genuine) never needed re-timing and did 22k miles before I sold it. Bike was last taxed in 2013 .... wonder if my CDI system is still fitted ... XDN128R. During initial testing the bike backfired and  almost blew my garage door off.
Ash
Post by: mike the bike on January 27, 2015, 12:49:32 PM
Don't remind me about differential calculus!
Anyway, I fitted a dyna system as well as Dyna coils a few years back.  It now pulls like a train going up hill.  The new coils are also rain proof - the OEM ones used to suffer from getting wet, despite all the sealant.
What I like about the Dyna is there's no extra box of electronics to wire in; it's all on the points plate.  I had to add an extra lead to supply 12v to the points plate but that was it.
Post by: Norniron on January 27, 2015, 07:19:33 PM
Can't be.
I copied it from his sohc shop page so i presume it is
Post by: Trigger on January 27, 2015, 07:23:54 PM
Can't be.
 ;D ;D ;D
Post by: bomber on January 27, 2015, 08:45:23 PM
I'm so, glad there is someone who struggling with understanding it too.
I thought the answer is simply pay another 99 to DS for electronic ignition... how wrong I was.
Still since I don't have 99 so I have to use original ignition, and it seems it is not a bad idea after all!
Post by: Norniron on January 27, 2015, 09:26:20 PM
I bought one from ds for the 400.i had to send it back,really really bad quality.
It was worth paying an extra £25 for the dyna s
Post by: LesterPiglet on January 27, 2015, 11:24:47 PM
Hondaman is $92 delivered.
http://forums.sohc4.net/index.php?topic=67543.0
Post by: Lobo on January 28, 2015, 09:41:13 AM
I too was sorely disappointed by the DSS unit... rather cheap(ly built) & nasty. It now languishes in a box somewhere... wish I'd set it back...
Happy with a UK Newtronic system @ £117 which dispenses with the points but keeps the advance / retard unit & the OEM coils.
Post by: bomber on January 28, 2015, 11:21:56 AM
Don't understand how DS part can be so bad.
Pictures of Dyna S show neet black plastic parts, while DS is all open, which is not ideal and prone for damage, but thats all.
It looks less protected I suppose it is saving some money.
Is it not working properly?
Please explain in plain language.
Thank you
