SOHC.co.uk Forums => Other Bikes => Topic started by: Laverda Dave on April 17, 2021, 11:05:54 AM
Title: Crankshaft oil seal fitting
Post by: Laverda Dave on April 17, 2021, 11:05:54 AM
Hi All,
A quick question........................
I ordered a complete seal kit for the Z400J and this included the two crankshaft oil seals.
I fitted the seals and all appeared to be fine, crackshaft turned, the lip was properly in place so I bolted the two crankcase halves together.  Skip forward a couple of hours and the tidy up and I noticed the old crankshaft seals had a ridge around the outside of the seal (as do Honda seals) to fit inside a machined groove in the crankcases. The new seals didn't have the ridge.
Question is do you think the new seals are OK? They are from Wemoto and they are a reputable company. The seals are Japan made. I really dont want to take thje engine apart but then again I dont want the new seals to blow under pressure.
What does the forum think....?
Title: Re: Crankshaft oil seal fitting
Post by: Lynx on April 17, 2021, 11:15:40 AM
As long as your engine breather is not blocked, they shouldn't be under pressure and so, they should be fine!
Sent from my HTC Desire 530 using Tapatalk
Post by: Bryanj on April 17, 2021, 11:51:23 AM
Agreed
Post by: Laverda Dave on April 17, 2021, 11:54:28 AM
Phew.....😨. Thanks guys👍. I can sleep tonight!
