SOHC.co.uk Forums => CB350/400 => Topic started by: McCabe-Thiele (Ted) on March 05, 2022, 02:01:27 PM
Can anyone point me in the right direction please I need a couple of these I think they are 3.5 mm size 4 way connector?
I do not want to cut the ones off my old loom as it might be of use to someone else when I have a clear out.
.(https://live.staticflickr.com/65535/51918456267_103109d4ca_k.jpg) (https://flic.kr/p/2n6REeH)4 way connectors (https://flic.kr/p/2n6REeH) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Look up kojaycat i have found odd items there before and good to deal with, or at least were.
3.5 will take 3.9 bullets
If it's black wire Ted it should have a shroud to protect earthing as that's a power source.
Correct one of the reasons I replaced the loom as insulating tape was everywhere presumably because the sleeves had been removed for some reason. I've sourced some connectors from kojaycat a bit of a wait for delivery as they are closed for holidays.
Not seen the 4-way 3.9mm socket connector on sale before, do you have the the product number/code? for kojaycat.
I have bought items from kojaycat before...good supplier.
They only do the 3.5 mm one its TB-3.5mm-5W-1PC
I had the same problem Ted, they are impossible to track down, I even tried a breakers yard to look at old looms but no body does them now they do multi block, I didn't want to use a block connecter on the 1 into 4 earth connecter so I had to solder 2 doubles together to ,get the same result/quote]
https://kojaycat.co.uk/epages/950000457.mobile/en_GB/?ObjectPath=/Shops/950000457/Products/TB-3.5mm-5W-1PC
That would have saved me a lot of messing about, when I posted that same question.LOL
They are japanese connectors, different from bullet connectors or fastons. In EU I usually find them on classic/ vintage automotive parts shops. Maybe you can find them in specialised electrical automotive shops?
