Other Stuff => Misc / Open => Topic started by: Goose on July 19, 2012, 04:43:31 PM
I'm about to start stipping the old manky and flakey paint off the engine and thought one of these dremel tools would do the trick. I've had a quick look on the website and there are dozens of varieties. I need the kit that does basic sanding with a polishing attachment - anone got one who can tell me what the best combination is?
thanks
I've found the battery ones to be barely powerful enough.
Hi Goose send Spitfire a message i'm sure he's pretty handy with a dremel he might be able to help you ;), cheers Mick.
I found a Blackspur dremel type mini drill in local odds and sods shop for £20 a couple of years ago, it has done a lot more work than my genuine dremel did before packing up dissapointingly soon in it's working life. Old minicraft / black and decker mini drills also last very well and come up on ebay. The accessories are widely available and when I last looked were far cheaper from non dremel brands. Lidl ones were very cheap when I last needed some, if they do stock a Parkside mini drill the quality of that stuff has inpressed me a lot, trouble is it's stocked when they feel like it rather than when you need it. Rolson also do bits that will fit most mini drills, a decent hardware shop should have a range of stuff - so far I've not found a brand of consumables to be better or worse than any other so I just buy cheapest.
Hi there, as Mick said I spent quite a lot of time with a Dremel when preparing my CB750F1 engine for painting, I also used lots of wooden stirrers from Macs, tons of Brillo pads, and lots of different drill mounted rotary wire brushes, this was after a thorough degrease.
The Dremel was most useful in the finned and difficult to get to areas, my Dremel is an old one that I bought in the late 90's, it's a mains one and works a treat, I fitted it with the multi chuck, it's also great for cleaning up carbs and the like.
One of the best Brushes that I used was an abrasive one rather than a wire brush type, it gets rid of paint and oxidised aluminium without gouging the metal, I'll have to have a look around the garage and see if I can find one to point you in the right direction, it was a genuine Dremel item from B&Q.
Found it Dremel 538.
Overall the Dremel was probably the most useful tool that I used when rebuilding the bike.
(http://i192.photobucket.com/albums/z244/DennisMcc/cleaning%20and%20painting%20the%20engine/crankcasesbig2.jpg)
Den
Frack me Spitfire that's really nice well done.You must have the patience of a saint.
Bitsa
PS fancy doing one for me?
It was a bit of a grind but worth it in the end, luckily I am retired so I have the time to do these sort of things, it could explain why it took me 2 years to get the bike finished though, and although I'm tempted by your kind offer to let me do one for you I don't think I'll do it again !
Den
Spitfire,
Understand you fully no problem but again well done.
Bitsa
Well Spitfire congratulations, that looks spot on. Is it painted if so what paint have you used like the finish allot.
I use a dremel good tool also put bits in my air die grinder. Cheers Tom.
Those casings look fantastic, great job.
Den
MAGNIFICENT
Thanks for the replies folks, thats helpful. Mind you, some high quality refurb work there for me to live up to!
