Other Stuff => Misc / Open => Topic started by: stuartni on September 17, 2013, 03:23:50 PM
Can anyone point my in the direction of 7mm ht lead joint/s supplier not having any luck.thanks
Vehicle wiring products had them in their last catalouge I had a look at.
Any use Stuart? Failing this a 'double-ended' screw insert joining your cables, with heat shrink cable as sheath? (assuming you're using copper cored HT leads versus the carbon type)
http://www.autoelectricsupplies.co.uk/product/682
NGK make them
http://www.ngksparkplugs.com/docs/Resistor_Covers.pdf
scroll to bottom and ask at your local emporium
Excellent guys quite like the look of the NGK one only thing is NGK uk dont stock them so will have or from america 8)
I could have done that for you Stu. ::)
