SOHC.co.uk Forums => CB650 => Topic started by: tosh on September 25, 2017, 06:59:52 PM
Title: Brake pad retaining spring clip
Post by: tosh on September 25, 2017, 06:59:52 PM
Finally got round to fitting new piston and seals in each calliper but I've found that on both sides the wee spring clip that passes through both retaining rods and over the shim are missing.No 3 in the diagram .. I can't find replacements anywhere inc Dave silver! My question is are these vital as I'm assuming they have been missing for many years ?   :-\
Title: Re: Brake pad retaining spring clip
Post by: Trigger on September 25, 2017, 07:23:52 PM
Do you have a part number ?
Post by: tosh on September 26, 2017, 08:06:34 AM
I think it is 45223425003 I've found them on Cms but the shipping is twice the price one 2 clips
Post by: Bryanj on September 26, 2017, 08:33:25 AM
From memory the ends go through holes in the pins to stop them sliding out, small "R" clips should do the same job, thats what a lot of cars use
Post by: Trigger on September 26, 2017, 08:46:47 AM
seem to be available everywhere >>> http://www.wemoto.com/parts/picture/ho-45223-425-003/
Post by: tosh on September 26, 2017, 04:58:57 PM
Yea just rang them and they can't get them as discontinued by Honda just haven't taken them down yet same story most places
Post by: hairygit on September 26, 2017, 05:03:22 PM
Found a used one, but it's in the U.S.  E-Bay number  362110555093
Post by: tosh on September 26, 2017, 05:21:39 PM
It has the R clips at the other end but the side in question has domed heads on the pins and I'm not sure what the purpose of the clip is, as it just seems to hook over the shim from what I can make out so maybe anti vibration??
Thanks Hairygit I will have a look
Post by: Trigger on September 26, 2017, 09:14:18 PM
Bliming heck, seem to be running out of stock. Here is a new one, I would buy this and make another with a bit of the right size wire.
http://www.ebay.co.uk/itm/NOS-Honda-CB650-CB750-Front-Caliper-Clip-OEM-45223-425-003-/192029374633?hash=item2cb5d7b8a9:g:7rgAAOSwHMJYLNtG
