SOHC.co.uk Forums => CB500/550 => Topic started by: Mike_Berkshire on April 23, 2024, 08:18:51 AM
Title: CB550 Oil Filter Bolt Removal
Post by: Mike_Berkshire on April 23, 2024, 08:18:51 AM
Im planning to lift the 550 engine out of the frame at the weekend and intended to take off the Oil Filter housing to make removal from the frame easier. The bolt on the oil filter housing looks horrendous, no flats left and I doubt a smaller socket tapped onto it would grip. I can probably get my large Molegrips on it but before I go down that route are there any tips for tackling this? I have given it a good squirt of WD and left it to soak in. Thanks
Title: Re: CB550 Oil Filter Bolt Removal
Post by: Johnwebley on April 23, 2024, 08:24:45 AM
What a beaut!
Good luck
Post by: Bryanj on April 23, 2024, 09:03:02 AM
I think its 3/16 whitworth socket that will hammer onto that and undo it, never failed me when working for a Honda dealer, might be 1/4, its a long time since i did this
Post by: K2-K6 on April 23, 2024, 09:08:50 AM
You could file the flats to give a little better chance with a smaller sized socket firstly.
The WD doesn't usually do much as they aren't usually stuck in conventional "corrosion" terms, more that they've been tightened too much to distort the filter housing and just making the torque required too high to turn easily.
The housing will rock clock and anti clockwise within it's pegged location, just a little. Turn if fully clockwise first, then while putting pressure on the bolt to undo it, try and turn the housing WITH the bolt, until it reaches it's furthest anti clockwise position.
Then hold the bolt and turn the filter back fully clockwise again, then repeat this to get the bolt moved. It's just fidgeting it (doesn't move much) but gradually ratchets the bolt to help it loosen. Once the pressure comes off the housing the bolt will usually move easily.
Post by: Johnny4428 on April 23, 2024, 12:36:05 PM
That looks a bit challenging! I would try the smaller socket on it first as Bryan suggested although very good tips from Nigel too, single hex socket ofcourse not the multi hex ones.
Post by: McCabe-Thiele (Ted) on April 23, 2024, 12:48:40 PM
The mix of Bryan & Nigels advice should work if you use a T bar rather than using a ratchet on the socket you can apply the force more evenly a third hand might help with the filer housing whilst you use the T bar - best of luck.
Post by: Mike_Berkshire on April 23, 2024, 01:47:08 PM
Its just too far gone. Smaller socket tried and it just broke away from the head of the bolt with a sprinkle of metal chips from the head. I think that I will try and remove the engine from the frame with the housing in situ and then try again when its on the bench and I have good access. Last resort will be to drill out/grind off (carefully) the remainder of the hex head so that the flange can be removed and then it should be possible to withdraw the filter housing over the oil bolt and then remove the remains of the oil bolt once the housing and filter have been removed? What a faff.
Post by: K2-K6 on April 23, 2024, 02:15:48 PM
If it's properly "farked" .... cheap socket, tap it on, weld it to it, then it'll come undone.
They don't get stuck on their threads, just compressed the seal o-ring and if done too tight by previous O then "splaying" the filter housing.
The bolt diameter is quite big as it houses the oil pressure bypass valve to accommodate if the paper filter gets blocked as emergency through route.
The flange is relatively small in it's overhang from that bolt diameter, but probably difficult to cut off without risking the housing.
A really good new/sharp set of "cobra" waterpump type pliers can get onto the outside of flange to succeed sometimes .... keep your fingers out the way though  :-[  in case they slip.
It's an odd one, because they aren't usually stuck that much, as in not seized solid, just enough to prevent easily coming undone with a mangled hex.
All because people avoid warning not to tighten them too much.
Post by: ozzybud on April 23, 2024, 02:30:22 PM
Get a set of these external bolt and stud extractors.
That Bolt will be out in seconds.
Ozzybud[attachimg=1]
Post by: Moorey on April 23, 2024, 02:32:47 PM
Cut a decent sized slot about 5mm across the hex and use a piece of 5mm steel in the slot and turn it with a fair sized adjustable spanner whilst holding the jaws of the adjuster hard up against the hex. It will come out.
Post by: Mike_Berkshire on April 23, 2024, 04:17:19 PM
Thanks for all the great tips - that bolt extractor kit only £28.99 on Amazon; seems like a bargain so I have gone for one of those. I wont try and do anything more with the bolt until I get the engine out so I can get at it properly; its going to be a fun weekend! Cheers all. Mike
Post by: McCabe-Thiele (Ted) on April 23, 2024, 05:23:12 PM
Be interesting to see how you get on with it - looks great bit of kit - how did I ever manage without one in the past?
Please let us know how effective it is Mike when it arrives and you do the magic.
Post by: davidcumbria on April 23, 2024, 10:22:26 PM
I have had such a kit for a couple of year after a recommendation from my car garage mechanic and it has worked well for me. I used it to remove the casing  gallery plug under the crankshaft of my 550 which had been completely rounded off by po. The harder you turn the more it bites in - got me out of a couple of scrapes.
Post by: McCabe-Thiele (Ted) on April 24, 2024, 10:24:39 AM
I only have one that I bought for a particular use - flank drive ring spanner they avoid rounding off bolt heads.
I would like a set but price is daft money - this is a used set!
.https://www.ebay.co.uk/itm/135029750512?itmmeta=01HW7PEYR3SW9R5QY1RJ5Y9E1Y&hash=item1f70667af0:g:yigAAOSwtaxl72oo&itmprp=enc%3AAQAJAAAA0LTuhXps%2FQn%2BbiSNiXJ0hUWnBSEYr2K7Lxk%2BcrhHN2qBAJb4rYBB9mcRiUWa8GgumqhozgP7KaziEG2slFzirrQWDwfDQZO1jTgmb958CcRaLmLWeUUokCrQqRqgaItU83EiOw0rFsx7J2fe2gUI4Tp5Csn1D0lWhCCuoboXaI%2FpjJ%2FEpjFljNswFpQ6pLrbUzSjJtPZhKlBJoyUgutom2BQsGolB%2FHvVL%2FpuVGA%2FLhg7UPQCe4egLPQ6R6uNv%2FDWn5%2FFHIK92TFiNclBHrZRsI%3D%7Ctkp%3ABk9SR5bsu_bhYw
Post by: K2-K6 on April 24, 2024, 10:37:03 AM
As interesting alternative Ted
https://www.ebay.co.uk/itm/390062925510 these are flank drive and very low profile ratchet head for access.
Another point for interest (I've already had an alternative manufacturer set like this) is that they make extremely good plug spanner setup for these 4 cylinder Honda engines, with the "pass through " arrangement being able to use the extension and a socket to drop over the plug .... being hollow, both item ... to make very useful reach and access for those two central plugs.
You'd need to check that plug facility yourself though as mine is a different make (now not available) Bahco also owned by SO too.
Post by: McCabe-Thiele (Ted) on April 24, 2024, 11:05:49 AM
I have the standard Bahco 1/4 drive set that someone here recommended a great little set.
Bahco/SO/Blue Point group appear to have cornered the market.
Post by: Mike_Berkshire on April 24, 2024, 03:52:18 PM
Victory is mine! The bolt extractor sockets didnt work although a great purchase for future use. Eventually I had to opt for cold chisel and the big hammer - thank goodness for the flange under the bolt head.
Post by: taysidedragon on April 24, 2024, 03:57:28 PM
Well done. Victory!
Post by: Johnwebley on April 24, 2024, 03:59:22 PM
Good for you,
The idea of the small head, is to stop it being tightened to much,
I also grease the O ring under the head to prevent it sticking/corroding
Post by: Deano400 on April 24, 2024, 04:09:23 PM
Check for the washer between the spring and the oil filter. Often stuck to the oil filter and often accidentally binned. I have 3 engines here and none of them had the washer.
BTW mine are 400s, I imagine yours has a similar washer.
Post by: McCabe-Thiele (Ted) on April 24, 2024, 04:30:02 PM
Result - you can't sometimes beat brute thuggery.👍👍👍
Post by: Johnwebley on April 24, 2024, 04:35:20 PM
Yes, the 500 has them
Fit between filter and spring
Post by: Mike_Berkshire on April 24, 2024, 05:05:57 PM
Nope - no washer on the one I removed. Spring, yes. Washer, nope.
Post by: Nurse Julie on April 24, 2024, 05:38:19 PM
A lot of owners throw the washer out with the old filter, over the padt 3 weeks, I've sold 15 of them from my Ebay page 😂😂😂
Post by: davidcumbria on April 24, 2024, 06:40:56 PM
Well done  Mike - very satisfying to overcome such problems
David
Post by: ozzybud on April 24, 2024, 06:45:39 PM
Great feeling. Good job
Very surprised the stud extractor did not work. Did you use the one size smaller than the one that fit and tap it on?
Post by: Mike_Berkshire on April 24, 2024, 09:49:29 PM
Yes and it just tore off some of the remaining metal but there was just a small nub left.
Still I’m sure they will come in useful in the future
Post by: Jan B on April 26, 2024, 10:34:00 AM
You must be chuffed.
What replacement bolt will you be using? There are non OEM bolts with a larger hex. Less change to get mangled.
Post by: Mike_Berkshire on April 26, 2024, 01:37:47 PM
You ust be chuffed.
Thanks Jan! Yes chuffed but more relieved that I got it out OK. I havent yet thought about what replacement but a good call that some have larger bolt heads. I will also need the washer that goes between the spring and oil filter. It was either never there or I threw it out with the old (ancient) oil filter I removed. I did have a dig through the bin but didnt find anything.
Post by: McCabe-Thiele (Ted) on April 26, 2024, 03:45:14 PM
I fitted this one 15420-300-020P a Honda part iirc 17 mm head listed for the CBX1000 that fits the 500/550 etc
I think it differs from the original as it has a bigger bolt head - not sure if its Chromed or something like BZP.
Some of the cheaper aftermarket ones do not have as many holes in the center section.
https://www.ebay.co.uk/itm/264943691840?itmmeta=01HWDDES73CKH5R32S12N9A5G9&hash=item3dafdfe840:g:u6QAAOSw8NtftZ1Z&itmprp=enc%3AAQAJAAAA8AzdMM%2BMWvZhhc3hpVrufY7HefzhlpBjKh9LzaHr%2BTT80HHYlIkG7YpopkBeJ%2FZ3XZh9zXeBaFEunnCDsd59kDVcH5j8xDbcFsICz9d5BtbEkzKUc2pnCo2OAF31Uob6BMrjg%2FrdKilBzxfgSWoyHWTZlQgnb0uBUEumpEYCd4%2FUT2PcHd4F%2FsGJlq6YMUyP9j3BJOUwkNMNTzoicdxObtnFl8FEShqtm0GMg1uF7hszwt80PGodPrm7IqxcdLonbebs--hlBAFjJNdpl8%2Fmn%2BQ1SU60yojghbXjfGLWmDOVzJ%2F1B52BKx6eaDVoCu32NA%3D%3D%7Ctkp%3ABFBM0pO7reNj
.https://www.ebay.co.uk/itm/264943686943?itmmeta=01HWDDES73YBCGWN4KZ8V7S89P&hash=item3dafdfd51f:g:u6QAAOSw8NtftZ1Z&itmprp=enc%3AAQAJAAAA8JrIwGRHmeU0aMJnday6MO%2B1H1pfpTS9yb76oegYbFuMXrq1Fl1eV3Tws9HdYd0FJbf7oUns3U14PrOi9z8Z3jatktB%2FXDiCvT%2FGOQFh2tzFT0YzXPxeBXbB20dSWVnUR%2FKnBFuZmiEtRZDfz%2FhR1QrFK6xQEg%2BM%2B1ueBOuFFm13NQ7hJ7JGLbhUuqQ2YU56hDA%2B%2Fxbqg4fIaeMTStWhhAmofAcfB86Lql5Kfyd0QAswCjkxo%2FBYXbBGAZWytMZAyU3khw5oOJAkxKLHXa4pZzVpInUxBW4Qvqikwqlf4TZEQlLpcsqu82Fgtl2rL1GVMg%3D%3D%7Ctkp%3ABk9SR9KTu63jYw
Post by: Johnwebley on April 26, 2024, 03:57:00 PM
Can I suggest when you fit the replacement, make sure you don't over tighten it,
Post by: McCabe-Thiele (Ted) on April 26, 2024, 05:00:15 PM
Good point John, most folk overtighten canister oil filter by hand often needing a chain grip tool to remove them.
I try to use the lower torque reading given or just by feel as the O ring becomes compressed.
Post by: Mike_Berkshire on April 26, 2024, 06:00:20 PM
Perfect, thanks! I now have a new challenge and have made a new post - cant seem to remove the rocker housing now! Cheers. Mike
Post by: McCabe-Thiele (Ted) on April 28, 2024, 03:49:57 PM
I have a cheaper Bahco set it was about £20 back in 2021 not sure why this one is so much more expensive.
Not sure what they/yoou  mean by "pass through" ?
Post by: K2-K6 on April 28, 2024, 05:58:38 PM
 "I have a cheaper Bahco set it was about £20 back in 2021 not sure why this one is so much more expensive.
Not sure what they/yoou  mean by "pass through" ?"
Both the socket and it's drive are hollow Ted.
Describing my set ... the sockets are driven by external hex (19mm think ) rather than 3/8 etc square, with the extension bar hollow too.
Think they were originally for "stud" work so you could slide the assembly over long bolts rather than need "deep" sockets.
Coincidentally, they can be arranged to make very competent plug spanner (plug top just goes inside the extension bar) and seem to fit into various cylinder head recesses easily, while not having too high bulk around head to prevent competent alignment etc.
By no means essential, but do work in quite severely restricted installation .... in some cases.
Mine also with "Swan neck" gentle curve in ratchet handle that gives very shallow stack height, guess low profile would be good description, but also flips over to place the handle up or down in relation to surrounding frame bits etc.
Post by: McCabe-Thiele (Ted) on April 28, 2024, 06:30:08 PM
Thanks for that.
Post by: davidcumbria on April 29, 2024, 09:19:11 AM
At the cheap end of the spectrum I got this  set for £12 and it’s worked fine the few times I’ve used it.
https://www.ebay.co.uk/itm/186259710038?itmmeta=01HWMERWT1A5J5Z87X54CXGX2A&hash=item2b5df1a056:g:bnIAAOSw-FNlWBiZ&itmprp=enc%3AAQAJAAAA4Ixni6gZDUrkYyG4gxLxSrTuhh2MV%2FQ88Ca5OGICFOCehspCfRqb%2F280IUMRlqU6A%2BMRiWbA%2FocTY10xuKcGdkPIl70fQRrTgCV--qE7o2j6sWMng2fdNeBw6gyfe8I47DxevbfhNNf9paNLUwGTOHcSd8RbTUbgNXcy6v7%2Fla9O3f5EX1tWTePIHBih1gYGma31Hs72tf8v01vIhqdGhc%2FYX6YB4Ep%2Fv1KgodUWAn31txfAVP4aWpuyKog3F%2FmgvsOnMQ7DL6USc4yypnbG4yqYl9uORIViTYYTwQVmix7a%7Ctkp%3ABk9SR5DN447lYw
Post by: McCabe-Thiele (Ted) on April 29, 2024, 09:29:44 AM
Seeing those David  reminded me of when a locking wheel nut on amy old Carlton stripped out.
At the time circa 1990 I ended up using a cold chisel to eventually get the nut to free off.
Post by: ka-ja on April 29, 2024, 09:36:43 AM
Those are based on Metrinch sockets, gripping on the flat sides of nuts, will also fit metric and imperial nut sizes in one set.
