SOHC.co.uk Forums => CB500/550 => Topic started by: PennoK3 on January 21, 2024, 05:51:45 PM
Title: CB550 K3 Airbox Fittings
Post by: PennoK3 on January 21, 2024, 05:51:45 PM
I am very close to having all the bits I need to rebuild my airbox apart from the parts identified as Stay A and Stay B (threaded brackets for the airbox top).   I have one of them but I don't know if its A or B, is there a way to identify it specifically ?
Title: Re: CB550 K3 Airbox Fittings
Post by: mickwinf on January 21, 2024, 09:24:12 PM
They are a different width where they fit in the recess in the airbox.
Post by: 3scs on January 21, 2024, 10:18:08 PM
Stay A is the narrow one 20mm stay B is the wide one 30mm
Post by: deltarider on January 22, 2024, 08:14:47 AM
This does not refer to the airbox side, but to the correct orientation of the boots between the carbs and the head.
Post by: PennoK3 on January 22, 2024, 10:16:44 AM
Thanks all its Stay B I need then.   CMSNL have one for £14.00 which seemed reasonable (ish) but not when you add £15.00 postage!!!!!!
Post by: mickwinf on January 22, 2024, 11:06:32 AM
I might have the bigger one, will check later
Post by: PennoK3 on January 22, 2024, 02:34:27 PM
That would be great, many thanks.
