SOHC.co.uk Forums => CB500/550 => Topic started by: Gary400/4 on February 19, 2024, 10:53:44 PM
Hello all, I have recently acquired a CB550/4 K project bike to sort out, I have owned these previously and enjoy them more than the CB400/4.
I have stripped the engine to check it over, the engine was literally seized together, it took a lot of effort to remove the cylinder head, the cylinder barrel had accumulation deposits around the front barrel studs. I ended up with a few chipped fins. On inspection of the cylinder bores, the piston ring end gaps were still in service, but not by a lot, so I have purchased a new set of standard rings. On inspection of one of the bores, I note that a scratch is evident about 1cm long by 1mm deep running horizontal in the cylinder wall. I will be honing the bores to help the new rings to bed in. But I am worried about a ring getting snagged on the scratch as it motions up and down at revs. Is this something to be alarmed about?
It's difficult to judge without seeing it, but if the scratch is as deep as you say I would be looking at a rebore.
Even then it might be too deep and new barrels or liners may be required.
+1 with Gareth's response. 1mm is very deep and I doubt even a +1.00mm rebore will remove it. Considering you now also have chipped fins I would personally be looking for another barrel but only once I'd got the whole engine apart and inspected especially if it has been sitting seized up.
If the scratch is only 1cm long and 1mm wide it shouldn't be an issue,
OK, it's not perfect, but the rings are at least 2mm or 3mm wide,
So they shouldn't drop in,
On 2 strokes the ports are far bigger,
Do you mean 1mm deep or wide? Wide probably ok but depp not.
If deep its too deep for a max honda size rebore but cruzin do a 3mm oversize kit taking it to 605 ish cc but dont expect a cheap rebore as that is a minimum of 6 passes per bore plus hone!
As has been said if it's 1mm deep then it's a problem.
I would look for a replacement block, Bryan sourced one for me last year that was spot on. Plus as you know he does rebores as well. He might have a piston kit.
Couldn’t you just replace the liner?
Many thanks for the responses, I especially like the comment by JohnWebly, about 2 stroke rings not snagging on ports.the new rings placed in the bores have an end gap of 0.279mm which is between 0.15 - 0.35mm standard ring gap. This means the bores are well within service. Given the scratch dilemma, I would prefer the replacement liner option. Does anyone know where I could obtain a standard liner with a bore of 58.5 mm?
Hi everyone I have posted a picture of the scratch in the bore, I am still in two minds about using the cylinder?
No pic seen here
In the gallery Bryan.
Gary you need to post pictures as attachment to your post! Gallery is mainly for bike pics!
Just seen photo, that liner is as rough as a bears arse and is useless. You need to source another liner, check the others as well. That's water damage and the damage can easily go right through the liner. It's beyond re bore.
I agree, its scrap
Badger where I come from Julie 😁
Thats because you're from oooop narth and I'm from darn sarf Ash 😂😂😂😂 I think everyone gets the gist though.
Badger here too, Herefordshire
Badger where I come from Ash - I think a Badgers rear end has very coarse hairs hence the expression - probably derived from the old working mans sport of Badger Baiting banned in 1835 - it took a tad longer to make the Fox hunting illegal - 2004 - just another 169 years. I've picked up Road Kill Badger they are weirdly coarse to the touch iirc from 50 years ago when I lived in the countryside.
My shaving brush is made with badger hair, maybe I should try using a CB550 liner for a closer shave :-)
They use a badger's pubes for shaving brushes! 🤣
Probably...
To the original poster i will see if i have some 550 cylinders for you butvgive me a week
Sorry for the flippant hijack of your thread Gary :-[ :-[
Getting back to to the original question .. I too would be finding a replacement liner/cylinder barrels.
Probably...
Don't you lads be catching TB then ...
just seen the picture,
yes its toast,
after watching Allen Millyard if you have a large gas BBQ, you could get the liner out OK, info on You tube,
liners are available,check this link
https://westwoodcylinderliners.co.uk/
When you're home alone they'll come out in your oven at 220°C
