SOHC.co.uk Forums => Other Bikes => Topic started by: andy120t on August 09, 2013, 06:33:46 AM
Any thoughts on what I should use for gearbox oil for an old Triumph - T100 500cc from 1960. The Haynes manual says SAE 90 gear oil, but I've not been able to locate that in the local car/Halfords in Hertford..
Does anyone here use anything widely available for this type of application?
- I'm on holiday next week so looking forward to getting down to some fettling!
Halfords Halfords Gear Oil EP 80W/90 GL-4 1L
Having looked online I may have answered the question for Halfords - does anyone use this stuff? Suitable for an old Triumph.
Any other brands that are recommended?
EP was designed for diffs but will work happily in gearboxes, you don't need the expensive synthetics or semi synthetics just straight mineral oil
I was told not to use EP in old boxes as at will damage the bronze bearings - i think it was one of those rumours going around.
Went into our local Norton experts shop (Mick Hemmings - google him - works on them and raced them for years + is a bit of a gearbox expert) and all he sells is modern EP, so I thought if its good enough for him.....
I ran it in my rebuilt T100a engine with no problems. And you can easily get it from Halfords, that stuff will be fine.
Tom
Hey Tom, do you know Mick Hemmings well?
I've got a '71 commando engine and gearbox that I need restoring and wondered if he's still taking on this type of work..? Hope you're enjoying the Brown 550...J
He's still going mate, still got the shop - must be near retirement age now, but I asked him about rebuilding my Dommie 99 gearbox about 3 months ago and he said it would be after Christmas till he got round to it as he was so busy.
He's always got plenty on - recently Peter Williams has announced that he's putting together a run of new bikes and Mick is doing the engines and boxes for these (15 I think), so i wouldn't think he'll be quick.
I rebuilt my Dominator engine last year after the camshaft woodruff key sheared (no damage luckily) I used one of Micks engine rebuild DVD's and it was a pretty easy process really, you're more than welcome to borrow it if you fancy? He also does a gearbox DVD.
I also use the same machine shop that he does for all of my engine work, so they're pretty clued up on Norton stuff - I'll happily drop anything to them if you like.
Thanks Tom. Appreciate that - yeah I've joined the owners club and purchased both DVD's so may well have a go myself. Just not used to working on British stuff, so will need to invest in some imperial tools and I know the 20M3 commando engine requires a few special tools. I'll drop you a line when I know which direction I'm going in. Cheers, James.
