SOHC.co.uk Forums => CB350/400 => Topic started by: BrianC500 on April 28, 2020, 02:43:24 PM
Hi,
I'm currently starting the rebuild of a 1975 model. While stripping and cleaning the coutershaft assembly I've hit a problem. I need to replace both the ball and needle bearings. The grooved twin row bearing is held in position by a sleeve. Will a normal 3 legged bearing puller pull this off? Pic is attached.
Thanks in advance
Not if pull on the gear
Would it be better if it was pressed out? Unfortunately I do need to replace the bearing as it is very growly.
