SOHC.co.uk Forums => CB350/400 => Topic started by: billdn on May 13, 2022, 01:36:22 PM
Just about to apply jointing compound to crankcase and not sure if it goes here, as shown on attached pic ?
I put Hondabond very sparingly on that part and the crankcase half - mains journal areas - it was there from new as it was a pig to remove when I was cleaning the crankcase halves.
Others here will confirm.
Cheers Ted, ditto on removal :-\
I found Acetone works well but it evaporates off fast so I had to soak it.
During my crank case groundhog days I got quite profficient at removing Hondabond!
