SOHC.co.uk Forums => CB500/550 => Topic started by: oldtuggie on May 15, 2020, 02:06:45 PM
Hi
Is it okay to use high temperature silicone to stick the rubber cylinder Bolt Caps down.
Thanks in advance
A smear of Honda Bond works well.
Cylinder bolt caps? Do you mean the rubber pontefract cakes(or pucks to the yanks) between head and cam cover
I read it as rubber cylinder bolt caps Bryan, so assumed he meant pucks, because he mentioned rubber 🤔🤔🤔
I was leaning that way Julie but prefer to clarify it
Yes the rubber Pontefract cakes
I've got Honda bond so I will use that
