SOHC.co.uk Forums => CB750 => Topic started by: ginger_jim on May 17, 2015, 03:25:12 PM
Hi all, bit confused about fitting. :o So after taking off the original units I have plugged in the new combined unit block connector. I now have the black, white and green regulator female spade connectors and also another green female spade that would have earthed the original rectifier 'hangin lose' The new combined unit has a black and red cable which splits to make two spade connectors. Im assuming that connecting these to the black and white regulator connectors is all i need to do, and the two green earth spades which would have earthed the original units are now redundant because earthing the new unit is taken care of by the green in the main block?
Dont panic! I have a very good tested earth
That sounds correct, if there's any spare leads off the old reg floating about, make sure they're taped up.
The instructions you get with the unit have been translated by someone with a questionable knowledge of the English vocabulary, not particularly confidence inspiring! ;D
Hi Jim,
Sounds all good - my only reservation being that you have 2 earth spades 'floating' free. Certainly the old earth to your regulator is redundant, but I think the earth to the old rectifier is shared with the alternator field coil.... & so should be properly connected.
This said, I'm working from CB400F / 750K2 diagrams... but all in all they all seem pretty standard in the charging department.
Simon
Hi Simon, my theory was that the combined unit must use a common earth and there is a green going into the block so i reckon its all fine.
Cheers :D
