SOHC.co.uk Forums => CB750 => Topic started by: r1_pete on October 11, 2015, 01:59:55 PM
Hope someone can help me, I just tried to fit the K2 fork gators onto the headlamp brackets, how on earth do you get the chrome trim ring on, it wont slide up the bracket 1st, if I put it on the gator first there is no way it will go on the bracket...
Should he ring be able to slide up the bracket? I have welded some new metal in where there was corrosion so may have ended up with them too big in diameter......
Hi Pete, put the chrome ring on the gator, fit the gaitor to the ear and twist the chrome ring up. Ralph did a post on fitting these but, can't find it.
