SOHC.co.uk Forums => CB350/400 => Topic started by: eem46 on June 19, 2018, 12:43:17 PM
Title: Bearings colorcode, double check.
Post by: eem46 on June 19, 2018, 12:43:17 PM
Dear All,
Just started on my second HondaCb400Four engine, still learing about the crank and rods color codes.
Please let me know if I have it correct! :-)
Crankcase:     B A B A A
Crank:           A1 A1 A1 A1 2
Conrods:        2 2 3 2
Crankcodes are: B1 A1 B1 A1 A2  which translate into Green, Yellow, Green, Yellow and Green?
Conrod codes: A2 A2 A3 A2, which translate into, Yellow, Yellow, Brown or Green?? and Yellow
Please confirm A3 conrod code, Brown or Green?
Thank you!
Kind regards,
Emiel
Title: Re: Bearings colorcode, double check.
Post by: eem46 on June 20, 2018, 07:30:44 AM
Thanks!
Kind regards,
Emiel
Post by: eem46 on June 20, 2018, 03:18:21 PM
True, yellow is not easy, CMSNL has them, but I just bought them in France from ebay.
Do you advise to renew the expensive conrod bolts (stretch bolts) of just re use them on my stock bike?
Or go for the new cheaper version (stiffer) bolt 13213-KVO-000?
I searched the forum for a answer on the bolts, but people say yes or no.
Post by: Trigger on June 20, 2018, 09:41:49 PM
As what Oddjob has said  ;)
Post by: eem46 on June 21, 2018, 07:23:32 AM
Ok thank! Which torque should I use? Add blue Loc-tite?
Kind regards,
Emiel
Post by: eem46 on June 25, 2018, 07:19:04 AM
Please advise!
Kind regards,
Emiel
Post by: Trigger on June 25, 2018, 07:42:30 AM
No nut lock needed. Make sure the threads are clean and dry, a wipe of Graphogen on new shells and torque to spec  ;)
Post by: eem46 on June 26, 2018, 07:21:10 AM
Thanks!
Will order Graphogen on ebay!
Kind regards,
Emiel
