SOHC.co.uk Forums => CB750 => Topic started by: legin101 on June 03, 2020, 04:23:04 PM
Title: clutch replacement
Post by: legin101 on June 03, 2020, 04:23:04 PM
Hi guys who would you recommend for a new clutch for a f2
cheers
nigel
Title: Re: clutch replacement
Post by: Nurse Julie on June 03, 2020, 05:27:26 PM
As in parts manufacture do you mean?
Or who to fit it?
Post by: legin101 on June 03, 2020, 05:41:30 PM
No who to buy one from ive searched all over the place, when i search it keeps bringing up later models due to the f2, is it the same clutch as the K models.
Post by: Nurse Julie on June 03, 2020, 05:46:13 PM
Personally, I have no idea about F2 Clutches but have you looked at EBC clutch list?
https://bikes.ebcbrakeshop.co.uk/honda_c275691_277054.htm
Post by: Nurse Julie on June 03, 2020, 05:50:38 PM
It's on their list, 8th line down.
[attachimg=1]
[attachimg=2]
Post by: legin101 on June 03, 2020, 06:36:37 PM
Thank you very much, its on order quick as that
nigel
Post by: Green1 on June 04, 2020, 09:45:35 PM
Be carefull when doing the lifter plate up I just chipped mine.   :(
Post by: Nurse Julie on June 04, 2020, 10:03:42 PM
That was a silly thing to do young Mick 🙄🙄🙄🙄
Post by: Green1 on June 04, 2020, 10:06:26 PM
As you know its all to easy too do.
Do you think I can get away with using it?
Post by: Nurse Julie on June 04, 2020, 10:08:04 PM
As you know its all to easy to do.
If it's only a corner that has chipped off, yes, it'll be fine but if its cracked through the hole, no.
Post by: Green1 on June 04, 2020, 10:09:26 PM
Bummer its just into the hole.
Post by: Nurse Julie on June 04, 2020, 10:18:41 PM
Post by: Green1 on June 04, 2020, 10:27:04 PM
Thats the answer I expected but didn't want to hear.
Sods law states I will buy another and snap that too.
Post by: philward on June 04, 2020, 11:19:41 PM
This may be an option Mick - https://good-bits.co.uk/product/cb750-sohc-clutch-actuating-hub/
Post by: legin101 on June 05, 2020, 09:02:52 AM
I wasn't aware of the problem so many thanks i will try not to do the same.
Post by: ader on June 08, 2020, 09:54:09 AM
I cracked the corner off the lifter plate, just into bolt hole, it seems to function ok. What is the potential damage if not replaced?
Post by: legin101 on June 08, 2020, 12:00:58 PM
now i have seen this infamous plate i can see why it happens, if the tension is taken off by all bolts at the same time then it will not break likewise when refitting take the tension by all bolts at the same time, now 3 bolt holes in good condition i would use a washer over the remaining hole and tighten to the specific torque.   that should be fine.
Post by: Bryanj on June 08, 2020, 01:06:33 PM
Forget torque just snug by hand
Post by: Green1 on June 27, 2020, 07:22:09 PM
I ordered the lifter plate from Goodbits on the 5th June and it arrived on the 8th so great service.
I have finally got around to fitting it today after work. I would go out on it to test my new clutch but I'v hurt my shoulder and can't twist the throttle  :'(
