Other Stuff => Interchangeability => Topic started by: Erwin83 on March 03, 2020, 10:17:36 PM
For those of you wanting to update the front fork of your CB (in my case a CB350f) with something modern...
A front fork of a KTM Duke 125 / 390 (or RC 125 / 390) is a direct fit.
Just order an extra top stem bearing (30mm ID instead of 26) and you're good to go. You need a 7mm spacer under the bottom stem bearing, but they come supplied in the All Balls kit.
I don't know about clearance towards the tank yet, but technically, it's a direct fit.
Only downside (for some): it's a single brake disc set-up. For my 350, more than enough.
Have you looked into rake/trail for this setup?
Yes. As in.. i know it will change as this new fork is 40mm offset and the CB fork is 60mm offset.
How that will affect handling... time will tell.
Added: fork is the same length as the CB fork at around 70cm uncompressed. Wheel axle is in the same spot (center of the fork)
Like a glove.
Good tip for anybody building a special.... 8)
Looks like a pretty cool setup. Nice work.
