SOHC.co.uk Forums => Other Bikes => Topic started by: Woodside on December 08, 2016, 06:52:35 PM
Ok chaps any one have any ideas on this one...
Popped out to the garage and it was the cb450's turn to be run up to temp...I try and rotate the bikes so over a couple of months they have all had a good run...If not used. ..
Well it started on one....nothing to unusual but normal the second one comes to life pretty quickly. ..
To cut a long story short one of the ht leads or plug caps looks like it's
Giving up...when I took it off it was like black mastic....all sticky and black ...a good clean and back on 2 straight from start...
I have now fitted new plugs and caps and its running sweet again but i have not touched the leads ...
Is this anything any one has seen and will the leads need changing
Yes to both mate
As always thanks bryan...
Kinda thought o would have to but wanted some reassuring
