SOHC.co.uk Forums => CB350/400 => Topic started by: DayvW on February 16, 2014, 08:26:14 AM
Hi,
Can anyone tell me the size I need to remove the generator?
Thanks.
Hi,
I just went to check as I made one on the lathe for my 350 and 400 and it was M18x1.5mm pitch - that is not the 'standard pitch for 18mm diameter (that's 2.5mm) but is an alternative pitch, so a bolt might be obtainable.
If you have a mate with a metric screwcutting lathe he might be kind enough to make one for you. I also made a plug to go in the end of the crank, so that the extractor couldn't damage the internal thread. I have a vague recollection that a 750 or 550 rear wheel spindle was the correct thread and could be used to extract the rotor - someone might confirm this but I don't have one to check.
Ian
Hi,
With some of the smaller Hondas I found the rear wheel spindle will do it.The 750 does not.
Bitsa
Yes, my CB650Z rear spindle fitted straight into the rotor and I used an old hub to slide along the shaft to whip it out. I remember this well as when the old hub got to the end of the shaft my finger was still there! F**k!
Thanks for the replies (and ouch!). I'll try a rear wheel spindle (and mind my finger!). I was going to get the Laser Flywheel puller if one the fittings was correct (which it sounds like it is if Machine-Mart is correct) - but maybe I don't need to. Excellent!
First things first - the bolt in there is on so unbelievably tight I can't shift it. Any hints and tips for removal? Is it a normal thread (not reversed I assume)? Should it be that tight? I've tried 'locking' the crank by putting a screw driver into the rotor and bracing against a cover bolt - but I'm worried that I'll damage it if I force it too much. Any suggestions (as ever) gratefully received.
It occurs to me that as I plan to split the crankcase (as I am perhaps foolishly - going the whole hog on this engine) - do I actually need to remove the rotor to do this? I am suddenly thinking perhaps not - that once the case is open I can lift out the crank with the con rods and rotor still attached - so as a unit - but is that right?
Thanks again for any pointers and suggestions.
Hi,
Rotor tool on ebay under honda 400/4, but I have seen cranks out of cases with rotor still on---ken
Yes you can remove the crank with the rotor on, but it needs to come off to fit a new oil seal (don't think it looks okay I'll use the old one, It WILL leak, and that means engine out and strip again :'() If the engine is still in the bike, stick it in gear and get someone to hold the back brake on, that will hold the crank while you undo the bolt, which is normal thread ie anticlockwise to loosen ;D
OK .. thanks .. hmm ... motor is on a bench (without the top half) - but it sounds like I need to remove the rotor - but at least I know the correct direction (many thanks) - just need to find a soft way to stop the crank turning ...
If you cant undo the bolt holding the rotor, put it in the boot of the car and go to your nearest tyre fitting emporium and ask a numpty nicely to use an air gun with apprpriate socket.
Excellent - thanks Oddjob - but wouldnt the extension bar damage the conrod eye - or am I needlessly worrying (I guess I must be if you've used this technique)?
bit of heat few small taps and off it comes
Yeah - I'll try the heat too - right now it's on solid - so if the heat doesnt help then it'll need quite a bit of leaning on (or thumping) which is always a tad worrying of course ...
Thanks oddjob, I'll try that .. Plus use a bit of heat and see how that goes. If that fails I have just bought a compressor, I figured it was going to be pretty useful in general if only for blowing away stuff initially, but an air gun feels a good investment! I saw that David silvers tool and found a laser one on machine mart that looks pretty much the same, it includes an m181.5r puller. Can't comment on quality, but is less than half the price. Mind you, rear axle bolt is even cheaper if that works .. Though as over time I want to tackle many bikes I think a puller is a useful addition to toolbox.
Hi,
I can certainly recommend Laser stuff - I bought an ABS rotor nut tool of theirs for my Jag XJ8, it was £24 plus post as opposed to the Jag one at £155!! It looks and performs exactly as the Jag one - good materials and workmanship.
I checked my rear wheel spindle on the 400 and it's smaller than the alternator rotor thread - so perhaps the bigger bikes spindle might fit, but that thread size is available if you can source a bolt.
Ian
When your done it should look like this :)
Thanks for the recommendation (and for checking) Ian - I'll get that Laser one then.
And Fisjon - indeed - looks lovely. I was going to clean up the engine with paint stripper and a dremel (indeed have on the rocker cover(s)) - but since then decided to go the whole hog, take all the bits out, bolt the casings back together (loosely) and get a Soda blast before a good clean and re-assembly (that's the plan anyway!). Its going to take time to get there (I only get part weekends at best usually :(, and have never done this before - so caution all the way! ) - but have to say am loving it (massively made all the more enjoyable through this forum and the unbelievably helpful people out there (I am rather a forum virgin!)). After seeing the state of the painting currently on my engine (awful, frankly) I am planning to leave her in the raw. But - is yours painted - it does look very good!?
This engine really was labour of love!
My buddy said, (after seeing my CB650Z) any chance of helping me with my 400/4 resto.
Ok I said and the engine was dumped in my garage complete with packed cow shit underneath (god knows where he had been).
A fortnight to clean all the crap off then a complete strip. It had a knackered cam belt adjuster and a 550 cam belt slider stuffed inside. No wonder the adjuster was shot. It cost £580 to rebuild.
Once the cases were stripped I just shoved it my bead blaster and gave it some stick. I then gave it some time with the high pressure washer making sure all the glass bead was out (you have to be meticulous) and dried it out. I painted the casings with a cheap engine paint as my mate was a bit of a scrooge but it came up really well. It's all down to preparation, if it is clean and smooth the paint will take well.
;D Well .. no cow poo on mine - just cack of a different nature. Well it looks good - I'll see how she is after cleaning and decide. Still - a long way from that yet!
Success! I got the rotor off (indeed have now stripped out the whole engine so I have bear crank cases). I used Oddjob's suggestion (though I did wrap the bar with insulation tape) - on the rotor bolt I needed an old torque wrench that has seized but is about 18inches long, held the engine from moving with left hand, braced my back against the bench, then heaved on the torque wrench. And eventually it gave -after heat and WD40 too! But it was really stuck fast. The Laser rotor puller was perfect -needed a few mallet taps - but got there. Such a relief! After that the rest of the strip was a doddle! Found the primary chain was absolutely shot (tested using OddJob's suggestion in another post - with the chain on its side, virtually the whole chain length touches!). The cam chain adjuster is also mashed and seized - so I'll be getting an improved one from DS (more expense - but a slapping noise at tick-over suggested this would be the case). Haven't measured the bearings yet - but all the gears, selectors etc look in fine fettle.
I will gladly do that (so far feel all I have done is gained loads from people on this forum and yet to give anything back -and I have loads more questions yet :)). One other thing is that when undoing a bolt on the end of the primary shaft (I think it was) with the crank locked by the OddJob technique (as I now call it!), whilst applying load the shaft actually skipped under the chain. By just resting my finger on the chain on the sprocket it was enough to hold it and the bolt came undone, but it tells me the chain is toast. Also - on another post I mention a graunching noise at certain (generally lower) revs that I have yet to identify - but I think may have been the primary chain skipping (a suspicion that also hastened this strip). Having said that the gears and dogs all look fine, no chips or wear that I can disern - so I'm assuming that if this were the case that the chain took the brunt of any scraping.
The graunching noise was when the engine was under load - like pulling away, sometimes after changing up. You could sometimes stop it by snapping the throttle off then on. At tick-over there was a kind of slapping nose which may have been the carbs out of balance, timing chain - or - indeed - perhaps the primary chain slapping. I'll take a look for that gouging - cant recall seeing anything - but then I wasn't looking. One end of each of the primary chain guides are worn - but (1) they appear to be discontinued and (2) I guess a knackered chain will have worn them and that a nice shiny new one wont.
I would change the bearings as a matter of course, if one is on it's way, disturbing it during a rebuild is the quickest way of pushing it 'over the edge' and you just don't want to do another strip down and rebuild to replace a whining bearing.
They can be expensive if you buy Honda originals, but each bearing has a number on it.
Take that number (and the bearing) to a good bearing supplier and tell him it is for a high revving Honda and he should be able to match the bearing exactly, at a fraction of the cost.
All bar one of the bearings that went into my cb650Z were made in Taiwan. Taiwan supplies Japan with bearings for the major bike manufacturers. You can get the same bearing in a different box for half the price!
I'll check those later - thanks for the tips re other suppliers of bearings - well worth bearing in mind (pun not intended :-[).
