Other Stuff => Misc / Open => Topic started by: SteveW on January 10, 2023, 04:08:09 PM
Was flicking tv channels yesterday and caught an old episode of The Repair Shop.
Guy was fixing dents in the tube of a vintage telescope with a ball bearing probably in excess of an inch diameter on the inside and a large magnet on the outside.
He said the magnet had a pull of 26kg and he slowly massaged the dents out by working the ball over the dent with the magnet.
Wonder if this would work on fuel tanks, exhausts etc. I appreciate the metal is probably thicker but might be worth a go.
I saw that Steve. I'd like to try that. The magnet looked quite small for the power, was it an electromagnet?
No, just a permanent magnet.
I guess you are still left with the other problem of stretched metal to hide.
My 500 has a nice crease on the left hand front where the front fork looks as though it has met the tank - also the old column had the bent lock stop. Not sure if they are related.
In the 1970s lead filler would have sorted it - it was great stuff to work with back in the day but not on fuel tanks!
Any dent removal is down to the type of metal, the thickness and the access to the rear of a dent. ;)
Was the telescope tube brass and non ferrous.
Yes.
Then I would think most of the magnetic force would be lost to the tank and virtually no control over the bearing inside. Try it on a biscuit tin.
Also thin walled and relatively soft?
