SOHC.co.uk Forums => CB350/400 => Topic started by: Nurse Julie on January 26, 2019, 03:34:00 PM
Part of this winters fettling included removing the plastic tubing on the front of loom which had gone brittle and split. Disconnected all the wires in the head lamp and they were in good nick, all connectors clean and nice and tight. Unlatched the block connector that joins the wires from the loom to the ignition and the red wire has completely corroded through with no wire left in the spade at all. How my bike started, or didn't conk out going over a bump, I will never know. There must have been just enough contact between the tip of the wire and spade to allow it to work.
[attachimg=1]
which bike Julie
which bike Julie
Hettie, the CB400/4
Blimey Julie...is this the one in the huge rebuild that has its own link in your signature? I'd have thought you'd missed nothing!
Looks like theres still more copper there then italian wiring too me.
Mick, you're finally learning!
I lernt this very recently when the guzzi didn't want to start.
It is indeed George but, I only did the engine and refurbed the front forks. The wiring is generally in very good condition and if the loom tubing hadn't of split through age, I wouldn't have even considered doing anything to the wiring at all. Just shows, things that are hidden need looking at to prevent a problem occurring.
Always the red or white with red tracer on these old Hondas that does that. Had similar a few times. Cannot think that it's ever caused the bike to stop though, always found it when doing something else. Famous last words.....
I had a new loom fitted to my bike but I got confused from the start, so I let a mechanic do the job instead, I wonder then did that job extend into the headlamp....I hate undoing the things!
How hard is it to get replacement plugs and things?
Not easy
Most of CB400/4 wiring loom connectors are in the head lamp bowl. It is like a birds nest in there when everything is connected and is an absolute pain to find or get to the wire you need. The block connecter the red wire came from is behind the head lamp and is still very awkward to get to as difficult to get hand/ fingers in there to disconnect.
Here is what goes in to the head lamp bucket [attachimg=1]
And the other ends
[attachimg=2]
Is that from the ignition switch block, Julie?
[attach=1]
Interesting that of its five wires, the red is the only one with issues. Do you think the connector crimps worked their way through the insulation, and time just took care of the rest?
Yes Matt, ignition block connector. The other 4 wires in the block were fine so I'm not sure why this happened to the red wire. But, that's old bikes and original wiring for you I suppose.
[attachimg=1]
Yup!
More current in that wire?, gets warmer than the others.
40 years of use, so 4x original planned life, not bad.
Looming issues.
Looming issues.
I think you are probably right. The red wire is slightly heavier duty than the others in the block. I think it's done well really.
Old wires are not my favourite things. This was the state of my wires from the points!
Dodgy old repairs don't help.
[attach=1]
Doesn't whatever current that comes through the red wire go through the black wire (except for the "park" position)? And the red is heavier than the black, huh? Interesting!
You should see the trouble they went through on the US bikes (combined front turn signal and "position light" indicators) to make it so when a turn signal is being used, the front position light filament in that indicator goes out...
I think its electolitic corrosion and fed by current flow or some kind of flux residue if it was soldered. Either way its almost always the re or white /red tracer wires that suffer. So much do that it's the first place I look on my 500/4s. Also had troubles on newer Hondas in the same areas. Ignition switch, red wire or the connections by the regulator rectifier. Only time it really provides a significant difficulty is the wires into the rectifier or reg rec on more modern bikes. I deem it sensible to carry a stock of spare electrical connectors in the workshops inventory, then its just a 10 minute job to fix, rather than wait for parts to arrive, or try soldering old wire to old reclaimed connectors. That and a supply of heat shrink tube. Very handy. Oh, and if I buy a bike, job 1, but out any of those blue or red pre insulated terminals bodgers love to use. They seem to attract corrosion.
It's electrolytic corrosion, with the big red wire being made of different flavour copper than the others. As they're crimped, flux isn't to blame.
All connectors are not (edit!) the same. I have seen various quality red bullet crimp connectors, the ones I have used (not bodged, thankyou!) are better than some but I'm damned if I can remember where I got them. Perhaps RS? The ones you get in blister packs from Halfrauds are questionable, as the insulator seems to deform completely when you crimp and then not return to it's original shape.
The ones i use look cheap and nast but the insulation is heat shrink to make a better seal.
If you get technical the corrosion depends on flow of current.
Worry not, i will replace it with the same quality connectors we use on all our bikes. Never short of replacements or spares for anything here at the House of Honda 😀😀😀
I am going to replace the grey insulating tape that Honda put over the 'junctions' in the loom with heat shrink though, before fitting the new loom cover. May as well whilst I'm there., it was falling off anyway.
Not a great photo but I found this when I stripped my F1 down, it was on the starter solenoid circuit if I remember correctly, I was amazed as I had never had any electrical problems at all with the bike luckily there were no other nasties. Just to make sure I went right through the harness cleaning up all the connectors and smearing them with dielectrical grease.
(https://imageshack.com/a/img921/9816/7a1xqF.jpg)
Wow, Dennis, that is bad! All the electric fluid has leaked right out!
At least the rare smoke stayed in!!
You can still get replacement smoke.
Accepted, there are good ones that are red or blue, but you know the generic halfords et al cheap blister pack items, I even have some - I think it's that the insulation on the cheap ones plus the crimp tools that come with them give a poor crimp, creating high resistance and that causes further issues. I must admit, they can be handy as a quick fix. But they do tend to get removed and replaced with the more expensive vwp jap connectors etc as appropriate once a bike goes into the workshop for serious fettling. The cheap crimp tools can deliver good results, used carefully. I think the main factor on the dreadful bullet connectors on reflection is they are often supplied as a one size fits all pack, designed for quite thick cables, its then quite hard to get them to tighten adequately, given they only have room for a single crimp, onto the copper, not a great deal of support from the insulation.
I think I need to find a new plug to go into the ignition on mine. Is there a source I can use or is it just a case of trial and error with some generics?
Vehicle wiring products do a fair range, but the plastic housings for the 6mm multi blade connectors are different, however the actual click in metal terminals are compatible so it's a case of re use the plastic but replace the metal, which does take some patience and a fine screwdriver and pliers to get the old metal contacts out.
