SOHC.co.uk Forums => Other Bikes => Topic started by: yozzer74 on May 12, 2018, 04:19:40 PM
Hi looking for some help been trying to bleed my breaks on GS I'm building .but can't get the leaver to firm up .it's got new break lines rebuilt calipers also using a front master cylinder from a gsxr 1000.could this be the issue?? There's no more air coming out of calipers now .[attachimg=1]
I can't see why that gsx mc would give a problem generally on another system, so should be ok.
When they are reluctant to bleed out if everything else is ok it may be worth trying another method. Pulling them out with a vacuum bleeder often gets them going or even a big syringe with rubber hose connected to the bleed valve to pull the fluid through.
Often when they get like this it's got air somewhere in the middle section brake pipe that just moves back and forth as you squeeze and release the lever.
Presume you are locking off the bleed valve before letting the lever go for another application? May just be a case of careful perseverance.
