SOHC.co.uk Forums => CB650 => Topic started by: tosh on January 25, 2016, 06:16:25 AM
Title: PD51A rebuild kits?
Post by: tosh on January 25, 2016, 06:16:25 AM
Hi, do any of you know where to source these from, I seem to be struggling to find any one who stocks the kits for this carb, or is there an alternative, say the 750 for example, it's really  just the gaskets, accelerator pump diaphragm  and o rings I'm in need of, cheers
Title: Re: PD51A rebuild kits?
Post by: jueby on January 25, 2016, 07:09:05 AM
Try this link:
http://www.motorradbay.de
You will def find kits for the 750. They share nearly everything with the carbs from a 650.
No kits comes with acc pump diagram. But on this site you can get a new acc pump diagram.
Good luck.
Post by: tosh on January 26, 2016, 05:58:22 AM
Cheers Jueby :) that's just what I was looking for, the only thing I can't seem to find on there is the acc pump diaphragm for the RC 03, they only seem to have the RC 05 one, which looks like it has a much shorter shaft on it. Do you know if the CB750 K2 one is the same as it looks to have the longer shaft?
Post by: jueby on January 28, 2016, 07:13:52 PM
Nope, can't answer that question. Hope someone else here can
