SOHC.co.uk Forums => CB500/550 => Topic started by: clive on June 24, 2010, 06:25:42 PM
got a set of gauges for balancing the carbs, the problem is that the manual says the reading should read 14-24 Hg, but my gauges read in bar's, has anybody overcome this problem, help appreciated. ???
I belive the readings all being equal is more inportant then the figure they are at. The manuals normally have a section at the rear with conversion charts for various units of measurement.
http://www.engineeringtoolbox.com/pressure-units-converter-d_569.html (http://www.engineeringtoolbox.com/pressure-units-converter-d_569.html)
Try this link has a whole series of conversion factors
thanks chaps, pikey,i was hoping for a simpler reply,as mi brains getting a bit confused as it is ;D
Matthew's reply is the important one.
It doesn't really matter what the dials read, it is the balance that is important.
