SOHC.co.uk Forums => CB350/400 => Topic started by: honstan3 on June 04, 2014, 05:50:11 PM
hi to all, yes are you like me when you are going for a run, and you look at either handlebar mirror just to get a great view of your elbows? ,so i thought, would it be best to adapt the mirrors? i.e. using a spare pairs,hacksaw near the top, purchase a tap and die set?, make a thread at each cut section, and with the spare mirrors cut two pieces 2 inchs long?from these and thread those and with some nuts and loctight job done, or does anyone know of another type of bike mirror (with the same thread) that i could use? many thanks. honstan3 p.s. you know summers coming, roadworks are just starting to appear ho-hum.!!!
Hi. Have a look at M & P site, search for mirror extenders. Got these for my 400/4. Easy to fit, well made, just the job! Your plans sounds a bit more tricky!
Hi
Not sure what type of mirrors you have but these might be of help
Bitsa
Bitsa, are those the cheap ones?
could be Trig as always a beer plus post
Bitsa
hi to all, thanks for the help and advice bitsa,are you selling those m/ extensions?, i looked up that site, might prove useful, they will raise the mirrors, but may need to make them longer so that i can see behind, i could get a secondhand strait- jacket, to keep my elbows in!!. cheers.
Honstan
They are I believe 8 mm extensions.some honda wing mirrors were seperate unlike my cb750s which I think are 10mm
There yours for a good beer plus post if you want them.Frack it 6 quid all in.
Over to you
Bitsa
hi bitsa, yes sounds good to me,as a newbie to this site how do i proceed!, can you e-mail me with your address?, paypal,any good?, or a rubber cheque! only joking!! let me know,cheers..honstan3.
Honstan
This not the exact type but some wing mirrors came on the basis of this design my extensions are designed for this style
www.ebay.co.uk/itm/pair-mirror-silver-flash-10mm-for-Honda-CM185-CM200-CM400-CB-CJ-NX-/111288406725?pt=UK_Motorcycle_Parts&hash=item19e94e52c5 though 8mm
Bitsa
Honstan
Did you get them yet?
Bitsa
hi see message!, cheers.honstan3.
hi bitsa, just received the bits in the post!,many thanks.honstan3.
