SOHC.co.uk Forums => CB500/550 => Topic started by: paulbaker1954 on June 11, 2020, 12:50:52 PM
My main loom to the headlight shell runs on the left of the frame above the tank front locating rubbers as in the picture. I have noticed that the routing causes the loom to flex when turning the bars lock to lock.
I am concerned this flexing will eventually damage the loom wiring and was just wondering if this is the correct routing?
Under the tank rubber, there should be a clip that goes on before the rubber that, the loom hangs in ;)
Like so
