SOHC.co.uk Forums => CB500/550 => Topic started by: 3scs on February 09, 2020, 10:39:40 AM
My cb 550 k3 when I bought it was made up of loads of bits that don’t belong on it I’m slowly replacing with correct bits as I find them it had what I think was a rear mudguard off a F1 fitted with the rear light unit with the reflectors down the outside edge I’ve acquired what I believe is the correct mudguard and the correct rear light which has the round reflector in the middle was just wondering if anyone knows what the other light unit is off it has a shorter wiring harness than the k3 one I’ve looked on cmsn it shows rear lense with only two screws on the f1
If you are on about the one in the second picture ? This looks like a match >> https://www.cmsnl.com/honda-cb750k7-four-1977-usa_model495/taillight-unit-non-oe_33701371980p/#.Xj_1U3d2uxQ
Or This >>> https://www.cmsnl.com/honda-cb750k7-four-1977-usa_model495/lens-tail-light_33702341671/#.Xj_2BXd2uxQ
If it is a original light, it should have a Stanley number on it ;)
I reckon the second pic is a US version, notice the 4 screws are not at the four corners like the UK ones.
The lense with the screws in the outer corners is HM16RC-B and the other is. HM16RC
