SOHC.co.uk Forums => CB750 => Topic started by: Rozabikes Tim on March 06, 2011, 11:36:15 AM
This would make her lift her skirts a bit??
A usual, cut and paste link - excuse my computer skills.
http://cgi.ebay.co.uk/HONDA-CB750-SOHC-DRAGSTER-SUPERCHARGER-SINTILA-CR750-/370489880500?pt=UK_Motorcycle_Parts&hash=item5642eaefb4#ht_1467wt_905 (http://cgi.ebay.co.uk/HONDA-CB750-SOHC-DRAGSTER-SUPERCHARGER-SINTILA-CR750-/370489880500?pt=UK_Motorcycle_Parts&hash=item5642eaefb4#ht_1467wt_905)
Contrary to what it says on the e-bay listing I was the original builder / owner of that engine.
This is a picture of the original bike
(http://i895.photobucket.com/albums/ac152/bsmeto/HondaDragbike.jpg)
The engine you see in the picture is the MkI which spread its innards all over Elvington airfield. You would be amazed what a diet of 80% nitromethane can do when things go wrong. However, I rebuilt or more to the point replaced the engine as there wasn't a great deal salvageable from the MkI. The MkII engine is the one in the listing. Unfortunately there are a few bits missing. The crankshaft that's in it came from the MkI which unfortunately did suffer some damage in the blow up and one of the big end journals has a grove in it courtesy of the rod breaking. Oh. by the way three of the rods broke and went through the cases in the original. As I have suggested large doses of nitro = potential mechanical carnage and in my case it did! However, I did have the crank professionally crack tested and refurbished, so despite the damage to one of the big ends it should (in theory) be OK. I hasten to add that I have spoken to the current vendor and he is aware of this.
Eric
Wow Eric thats some machine you had, was it fast and is the seat made from a bale of straw
Pete
"was it fast?" Pete, thats a classic.How fast does it need to be to explode all over an airfield?...
The acceleration was phenomenal. As to how fast it would go I never got the chance to find out due to forementioned engine blowing itself to bits the first time I ever rode the thing. It should in theory have run the quarter mile in about 7.5 seconds with a terminal speed of 180mph. The cause of the mechanical mayhem was the jockey pulley for the magneto drive slipping out of position allowing the belt to slip and hence the ignition going awry. It sure did make a mess and a very expensive mess at that. Buyer beware!
Eric
