SOHC.co.uk Forums => CB750 => Topic started by: JonnyHonda on November 18, 2003, 01:24:48 AM
I`ve had my CB750 for about 3 months, bought it as a running repair.
Sounds like an electrical problem. Check the Plug leads are not damp/loose etc.
On these bikes a fault o
Had the same problem once and it turnedout to be blocked jets.
Hi,
Had a similar problem with my '77 550F2. The bike would start and idle ok but would not pull much above 40-45 mph. If the innards of the points stator plate are similar (which I think they are) it might be worth looking at the auto-advance mechanism - see of the springs are ok and the mechanism is not sticking. I cleaned mine and the problem went away.
Cheers,
Pete.
EDIT: Check this out in the AvantGo section of this website: http://www.honda-sohc.co.uk/print.php?sid=19
[Edited on 8/5/2005 by fothers]
