SOHC.co.uk Forums => CB500/550 => Topic started by: vraksianrebel on January 18, 2019, 11:02:37 AM
Title: My 550f,
Post by: vraksianrebel on January 18, 2019, 11:02:37 AM
so the bike got delivered today :) sadly i am still away with work but i got sent a photo and will be going over it once i am back.
i know there is parts missing and i am sure plenty of other parts will need replacing or restoring but i am really excited about it all
[attach=1]
Title: Re: My 550f,
Post by: Davelu88 on January 18, 2019, 11:08:07 AM
 Looks good ,Enjoy putting it back on the road  ;D ;D ;D
Title: Re: My 550f,
Post by: Nurse Julie on January 18, 2019, 11:26:47 AM
Title: Re: My 550f,
Post by: Johnwebley on January 18, 2019, 11:51:23 AM
A very nice starting point.
Have fun.The feeling you will get when riding it.after you have stripped. Rebuilt. The occasional curse.And mistakes.
This will put a smile on your face.es wide as the sun !!
Its why we all do it
Title: Re: My 550f,
Post by: Laverda Dave on January 18, 2019, 11:58:31 AM
Great starting point, the main bits are all there.
Spanners at the ready......
Title: Re: My 550f,
Post by: vraksianrebel on January 18, 2019, 01:01:21 PM
i have to finish my CG125 cafe project first then this one will get started, perfect chance to start gathering parts first lol
Title: Re: My 550f,
Post by: mickwinf on January 18, 2019, 01:59:16 PM
That looks pretty good for a restoration project, chrome bits are hard to get in good condition, also the exhaust headers are the original ones so rare in good nick.
Title: Re: My 550f,
Post by: vraksianrebel on January 18, 2019, 02:11:09 PM
yeah all the chrome looks good, the stanchions will need replacing but thats to be expected, the tank seems solid and fairly clean inside, airbox is missing whatever connects to the carbs.
is it possible to get a collector/exhaust thats fairly in keeping? rather than the cherry bomb
Title: Re: My 550f,
Post by: Laverda Dave on January 18, 2019, 03:15:03 PM
If the stanctions are straight (or slightly bent) get them straightened and hard chrome plated by Philpotts in Luton. The finish is far superior to the normal decrotive chrome plate fitted as standard. Price is about £140 for both stanctions. Turn around time is 4weeks. They will also rechrome the top nuts if you ask for an additional cost.
Title: Re: My 550f,
Post by: vraksianrebel on January 18, 2019, 03:43:49 PM
That’s good to know. Same surname as well wonder if they are relation lol
Title: Re: My 550f,
Post by: Allington (Steve) on January 18, 2019, 03:52:15 PM
Philpotts are excellent and been around forever too.
Title: Re: My 550f,
Post by: SteveD CB500K0 on January 23, 2019, 11:47:39 AM
When adding photos, select "Inline Fullsize Image" from the drop-down menu.
It's by far the best presentation - but I can't set it as a default...   :(
Steve
Title: Re: My 550f,
Post by: vraksianrebel on January 23, 2019, 11:58:40 AM
ah sorry. do you want me to go back and edit it? if i can
Title: Re: My 550f,
Post by: SteveD CB500K0 on January 23, 2019, 01:32:23 PM
I don't know if you can.
I could but only by downloading each image and re-attaching it using the different style.
Steve
Title: Re: My 550f,
Post by: vraksianrebel on January 23, 2019, 01:35:13 PM
Yeah the rear brake lever is an odd one its really bent but seems to work, sadly the missing bits are the first annoyance. little things that really annoy me like the starter push button has been removed? is that even something that i can replace? the wires are all still there just going to nothing.
the biggest annoyance is that whoever robbed the rubbers connecting the carbs and the plastic airbox have obviously levered them off both sides and slightly bent the carb mouth on both sides. i am going to have to try and sort that out once the weather isn't quite as cold.
Steve i tried and it really doesn't seem possible without just deleting and redoing the posts.
Title: Re: My 550f,
Post by: vraksianrebel on January 23, 2019, 01:38:35 PM
[attachimg=1][attachimg=2][attachimg=3][attachimg=4][attachimg=5]
trying again
Title: Re: My 550f,
Post by: vraksianrebel on January 23, 2019, 01:42:09 PM
hopefully thats worked a bit better
Title: Re: My 550f,
Post by: vraksianrebel on January 23, 2019, 01:48:46 PM
so the list of what i can see if missing is
clutch lever
ignition barrel (already ordered one)
starter push button
Tacho
brake master reservoir cap
right foot pegs (already got a replacement front, didn't realise the rear was missing as well)
rear indicators (i have the rear indicators from my old Brazilian CG125 that look like they might match so need to check that)
air box lid
whatever connects the airbox to the carbs
side panels.
4 million other little bits i haven't noticed yet.
step one is going to be ultrasonic bath for the carbs and linkage i think
Title: Re: My 550f,
Post by: Bryanj on January 23, 2019, 02:51:25 PM
You are lucky the carb to airbox rubbers are same as 500 and available pattern. Start button is the complicated switch i would get a UK switch so you can turn the lights off, the switch you have has a big plastic bit inside so the lights are turned off when the button is pushed, there is someone in US 3d printing the plastic bit that breaks but you still need the button and connectors which cant be got. Most of the rest should be readily available look at cmsnl for parts diagrams and numbers
Title: Re: My 550f,
Post by: mickwinf on January 23, 2019, 04:03:36 PM
i have an airbox lid and a mastercylinder top, i think also i have some rear footrests and have some indicators but not sure what fixes them to the grabrail
Title: Re: My 550f,
Post by: mickwinf on January 23, 2019, 05:10:48 PM
Just had a quick look in the garage and i have got a pair of rear footrests, a mastercylinder top, a couple of decent indicators but no brackets, and an airfilter top. I also have some switches that you could canibalise to fix your starter and also possibly convert to uk spec.
Title: Re: My 550f,
Post by: matthewmosse on January 23, 2019, 07:42:53 PM
Sweet little bike, not much rust, nice find. Shame about the dented carbs, best not try to bend that back until its warm at the least, really I suspect they'd benefit from annealing before bending back... bit of a risk they'd split. I might be tempted to see if they will seal like that rather than risk a cracked carb. The rest of the faults are fairly easily put right, then see if it's a runner..... I take it, that it turns over ok.
Title: Re: My 550f,
Post by: vraksianrebel on January 23, 2019, 11:57:50 PM
Mick awesome news I’ll send you a private message.
Yeah it’s a bugfer about the carbs, they aren’t badly bent so I suspect it will seal as is id just prefer them to be round if I can sort it
Title: Re: My 550f,
Post by: vraksianrebel on January 25, 2019, 02:56:53 PM
Ah, one of the carbs is totally ruined. Does anyone have a right hand side outer carb?[attachimg=1]
Title: Re: My 550f,
Post by: vraksianrebel on January 25, 2019, 03:40:03 PM
so I think ideally I need to replace the two outer carbs. The right side is destroyed and the left is just bent enough I think it’ll  struggle to seal
Title: Re: My 550f,
Post by: mickwinf on January 25, 2019, 11:03:08 PM
guess who might have them?
Title: Re: My 550f,
Post by: vraksianrebel on January 26, 2019, 08:10:42 AM
Ah mick, you’re proving to be an absolute life saver I’ll send you another pm
