SOHC.co.uk Forums => CB350/400 => Topic started by: oldchuffer on August 17, 2023, 06:08:08 PM
I have two silencers in good condition externally, looking at the internals i can see an internal pipe, on one the gap between this and the outer wall is larger, is that a problem. Also i took out some mangled what looks like a gasket or seal from inside the pipe, i'm assuming its a gasket which comes with the "clamp and gasket" set but it seems quite soft.
Sorry for the rambling but i'm a bit confused. Many thanks for any advice.[attachimg=1][attachimg=2][attachimg=3]
The soft stuff is to stop the inner pipe rattling against the outer skin ;)
