SOHC.co.uk Forums => CB500/550 => Topic started by: Ashdowner on March 01, 2016, 07:36:55 PM
The standard return (B) throttle cable is 83cm long. Therefore it's not long enough to go from the throttle through the forks and instead has to go on the outside of the RH fork before it goes under the tank and down to the carb link. This results in it kinking where it meets the frame under the tank. Does everyone have the same problem?
