SOHC.co.uk Forums => Other Bikes => Topic started by: hondatri on March 24, 2014, 08:01:04 PM
I am trying to help an elderly neighbour get his cyclemotor going again. It is a Bernardi engine that bolts onto bicycle driving the back wheel. It was not pulling so he asked me as I have bikes to have a look at it. I found the two piston rings broken and Have been looking for 2 or for a piston and rings. The Piston Dia is 34mm. The Engine is a BERNARDI made in Italy European Patent 82830113 5.
I would appreciate any help in locating parts. I would like to get the Old Boy Mobile again as I miss seeing him potter around on it. You were likely to see him anywhere on it
Give Barry a bell at T&L Engineering in Bedford. He has more cross references than me.
Try these people www.fwthornton.co.uk/ they specialise in old engine parts.
Well guys thanks for replies I have sourced the Rings at Gardenhire and supplies.Now for the Stupid part I did not mark the piston on removal and dont know which way round it goes and there is no arrow on top.The piston Skirt is shorter on one side and would like to know does it go to inlet or exhaust, I am not familiar with smpkers
Hi,
Try matching the piston/barrel port cutaways before you build it up by sliding the piston into the cylinder, any transfer ports should be in line with each other----ken
Many two-smoke pistons have the ring's end gap pegged so that they pass up and down on a part of the barrel that has no ports in it i.e. solid wall.
if looking down on the piston/barrel top with exhaust pointing away from you, then the rings are often pegged at about 7o'clock and 5o'clock positions on a conventional two stroke setup.
If you fit the piston opposite to this, then the ring ends drop into the exhaust port and snap them when turned over....a fairly common cock-up.
Put a felt pen mark on the piston top to align with the ring pegs and put the barrel on WITHOUT the rings, and gently turn it over to see if the marks line up with the right part of the barrel and miss all the ports.....Bob's your uncle.....hopefully
Thanks Guys for suggestions I will get back to engine tomorrow and try your suggestions.
