SOHC.co.uk Forums => CB500/550 => Topic started by: oldboy on December 04, 2021, 02:34:42 PM
Sorry, another paint question. Anyone on this forum used AutoTek sliver/grey VHT engine paint for their crank cases. Tried the Simoniz aluminum VHT on the barrels and it seems a bit to bright for my liking.
Sorry, iv’e not used that product. I thought the same about the simoniz, but having assembled the whole engine and fitted in place it seems to dull down, but remain ‘fresh’ looking.
Interesting!! I may just get a can and give it a go, maybe on the cambox breather cover, something easy to strip the paint off should it look crap or is affected by a few drops of petrol!! Unless anybody comes up with a bad experience with this paint.
The Simoniz SIMVHT31D is the closest colour to factory finish we have ever found.
[attachimg=1]
Must admit looks nicer in the frame than the engine sat alone on the bench. On scrolling through the parts list on Dave Silver site, they actually sells this Autotek paint in Silver/grey??
Have you air cured and then oven cured yet ?
Haven't actually sprayed the cases yet, just the barrels and as yet there just air dried. Is the paint your using the Simonize Silver or the Alluminum finish??
This one. SIMVHT31D
[attachimg=1]
Looks like we've found the problem!!! Using the wrong paint!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oldboy by name, Oldboy by nature!! What a pillock!!
At least you stopped and questioned it when you were unsure.
Has anyone tried to cure a whole engine at all.
Another question for "the nurse", once oven cured is the paint petrol resistant??
Highly petrol resistant but not totally petrol proof but then we've never found any paint that is 100% petrol proof. If you soak your painted engine in Petrol, eventually the paint will lift. Any dribbles of fuel, just wipe off, and the paint will be fine.
Has anybody done CeraKote
Thinking of doing my cases in clear or silver as they at the moment are still bare due to other distractions such as the rear disc conversion
(https://uploads.tapatalk-cdn.com/20211204/14c6aa314f49bdd4df683282b27c9a19.jpg)
Is meant to be the biz as lots of the rd boys used this for their exhausts so really good for high temps and super tough and totallly fuel proof
Have made enquiries, but is very expensive. Have seen powder coated cases which look very nice and also because it's thicker so it covers the blemishes in the aluminum better than that Cerakote, which is only microns thick.
Nice stand by the way!!
I always worry about powder coating....both in terms of its heat handling ability over time, and the horrible issue of dealing with it if it cracks or flakes.
I would always paint rather than powder coat a frame, but I can see why people powder coat a frame.
Engines, however, would have lots of raw edges, where every gasket surface was, and thats usually where corrosion starts, working under the coating.
My cases have been vapour blasted and thoroughly cleaned so I'm going the spray paint route with the paint suggested by "the nurse"!!
As for our bikes, I don't like powder coating. First, I don't like the looks of it. It is so obvious for anyone to see that a frame has been 'powdered'. Then the problems it can bring when preparations have not been a 100%. Many had 'surprises' afterwards, when holes that should have been left open, have received a layer that involves extra labour to remove. What's wrong with some spray paint? I mean, Honda did it...
Also I don't like to paint my engine. A CB500? Notorious for oil sweating sooner or later, no matter what you have done. And once more... it's so obvious for anyone to see. Also I don't know what the consequences are for the temperature household.
I generally prefer spray paint although I had my frame only powder coated - it was primarily to save the hard work of cleaning the old frame plus it was not that expensive locally - I also chose a colour that that I can touch in if needed as it's a known RAL code - yes it will not be perfect if touched in but doable.
Through sheer luck I have had no issues with fitting bolts etc - the bloke that did the job was a biker so where it was not masked up the powder coat was not sprayed inside holes etc. I would not powder coat any part of the engine.
Al, I ceracoted the 400 lump earlier in the year. Vapour blasted the granny out of it and had the lot ceracoted in clear. Looks great but no so bling as the factory fresh look of the SIMVHT31D
I love it but also love the factory fresh painted motors but this one was to be a more classic finish and we think it looks great. Cost me about 120 for all of it which I thought was rather cheap but I guess it depends where you go (https://uploads.tapatalk-cdn.com/20211205/e69dea2fe79e4c5d12995b6fc7e63917.jpg)
Hi Roo
Who was the company you used please?
Best wishes Al
Cameleon vapour Blasting in Yeovil, i caught him on a good day hence the price. He does all my stuff now, he's a cracking chap. Should have been £300 with the carbs I think, top job.He's ceramic blacking the pipes for me at the min and vaping the carbs for Mejima while hes on with it.
www.chameleonvapourblasting.co.uk/
Hi Roo
Thanks for the contact details
Not too far for me as in Swindon so think I will tap him after xmas and when I am back on me feet after my back operation next week
Have a good one
Best wishes Al
No worries Al, if yer coming down this way then come for a moan and a brew in the shed of doom, be good to see yer 8)
That sounds like a plan
Maybe see you in the spring
Best wishes and thanks for the invite Al
