SOHC.co.uk Forums => CB500/550 => Topic started by: Ibby4585 on November 01, 2020, 09:39:57 AM
Hi.
Still waiting for my Clymer mag to come, could someone tell me the size of the main tube fuses please?
Kris
15a main fuse. 7a headlight and 5a tail.
Lovely cheers
Size is 25mm. A bit hard to get nowadays.
Yes indeed, I did manage to source 25mm fuses off eBay after a bit of searching but by the time I got them home they were getting on for a quid each.
Brilliant cheers.
Yes just got some thinner ones from Halfords for the moment judy to test things, but will buys some correct ones tonight.
if you don't mind it not being standard fit a new fuse box for blade type
Unfortunately I'm mr standard and original, but I have though about that.
I found that with the standard fuse box the fuses would vibrate downwards and come out of their holders.
Even with squeezing the holder together they still did it.
Replaced with a 4 way blade fuse box, so i have a spare as well.
Hi Ibby4585
I can source 15A 8A & 5A Glass fuses (30mm L x 6.4mm Dia,) fairly cheaply but have yet to be able to find a source of 8A ones Try looking on the M&P motorcycle website will give you a idea of cost I have a trade account with them if that helps you
Nigel
There is an "age" problem with these fuse boxes in that the clips loose their "springiness" so the joint becomes a high resistance and heats up, frequntly enough to break the contact between fuse and end cap(a swine to diagnose as the fuse looks good) and has been known to interupt the contact at back of fuse box and melt plastic box
Hi Ibby4585
Nigel
Cheers Nigel.
Will have a look around.
Kris
