SOHC.co.uk Forums => CB350/400 => Topic started by: Deano400 on October 24, 2018, 08:33:02 PM
Title: Carburettor Insulators
Post by: Deano400 on October 24, 2018, 08:33:02 PM
Can anyone enlighten me as to what the divots are for in two of the carburettor insulators?
Title: Re: Carburettor Insulators
Post by: Athame57 on October 24, 2018, 08:38:01 PM
They look to me as something to ease handling, hold between finger and thumb? :-\
Post by: Deano400 on October 24, 2018, 08:39:28 PM
Thing is only two out of the four have them. They are listed under different part numbers.
Post by: Nurse Julie on October 24, 2018, 10:00:51 PM
What part is that ?, I cant even work out where it fits on the carbs  ;D
Post by: Davelu88 on October 24, 2018, 10:35:01 PM
They look like inlet manifold rubber ( carb to cylinder head) ;D
Post by: Nurse Julie on October 24, 2018, 10:43:27 PM
Ah yes Dave, I can see that now 🙄🙄🙄. Off the top of my head and without looking at mine, I don't know why 2 have those flat spots but I do know that the 2 outers are different than the 2 inner ones, slightly different angle and length if I remember correctly.
Post by: Davelu88 on October 24, 2018, 10:52:28 PM
I cant remember what 2 are outer and what 2 are inner as mine are off bike  :-[
Post by: Nurse Julie on October 24, 2018, 10:56:33 PM
Mine are on the bike so I will look in the morning and report back.
Post by: taysidedragon on October 24, 2018, 11:39:54 PM
If you look carefully, there are numbers on them. 👍
Post by: Athame57 on October 25, 2018, 04:11:53 AM
What if I can't see the numbers?
Post by: Laverda Dave on October 25, 2018, 09:48:59 AM
The numbers are raised and are on the edge of the rubber where the butt up against the carbs. So in other words you'll need a giraffe's neck to see them and the carbs are also likely to block any view.
I fitted a new set to my 400/4 bought from DS. I didn't see markings when originally installing them and it was only after struggling to fit the carb bank when I looked again and noticed the faint, raised numbers. I think they were numbered 1 to 4.
Post by: Nurse Julie on October 25, 2018, 10:14:54 AM
All 4 of mine have a flat spot on both top and bottom, simple when you think about it, you wouldn't be able to get the screws in there if the flat spot wasn't there. No idea if mine have numbers, eyes not that good 😀😀😀
[attachimg=1]
Post by: Athame57 on October 25, 2018, 10:36:10 AM
(Attachment Link)
Surely you don't (or didn't) drive a Cortina?
Post by: Nurse Julie on October 25, 2018, 10:39:53 AM
(Attachment Link)
Post by: Laverda Dave on October 25, 2018, 10:49:19 AM
I've just had a rummage through my old parts box and found the insulators. Apologies for the poor photo but the camera wouldn't focus..... Anyway, the number is on the insulator to the right of the fixing hole. They are numbered 1-4. I assume they are fitted with the number at the top. This will mean you cannot see numbers 1&2 as they will be obscured but you should see 3&4 as they will be on right hand side of the mounting set screw.
Post by: Laverda Dave on October 25, 2018, 10:52:22 AM
Opp's my last post contained a Senior moment..... If you take the petrol tank off you should be able to see the tops of all the insulators and there all the numbers..... Simples  ::)
Post by: Deano400 on October 25, 2018, 10:55:30 AM
Have now found the numbering after reading Laverda120's post. Would still like to know what the divots are for though on two of them.
Post by: Davelu88 on October 25, 2018, 11:04:45 AM
Just looked at mine and apart from the 1 and 4 cut away which I guess as others have said is for grip I can't see any difference
Post by: Bryanj on October 25, 2018, 11:24:50 AM
The divots are where the golf club missed
Post by: Nurse Julie on October 25, 2018, 02:33:38 PM
Ok, I have had a proper look and rummage now. The flat sides face each other on carbs 2 and 3. When everything is in place, the big fat breather pipe from the top of the engine goes down between carbs 2 and 3 and through to the air box assembly. Without these two flat spots, the pipe would be very, very to get through, almost impossible by the looks of it, so this design stops the pipe from getting crimped.
[attachimg=1]
Post by: taysidedragon on October 25, 2018, 03:24:57 PM
Julie, that's a good theory, but the engine breather hose goes over the top of the carbs, in the frame clip under the frame tube alongside the wiring harness, down behind the plastic air box and joins the contraption under the air filter.
The routing is shown on p87 of the dealer manual. I guess this keeps the rubber hose away from the engine heat as much as possible.
Post by: Nurse Julie on October 25, 2018, 03:45:26 PM
Do you know something, that's bloody amazing and yes, I can see it on page 87. My old 400/4 and this one has it routed between the carbs, I will have to re route it but the angle at the bottom before it goes into the air box bit, would be so acute, I would worry it would clamp itself off.
Edit...does anyone know if the original factory fitted breather pipe had bends shaped in to it?
Post by: paul G on October 25, 2018, 03:51:45 PM
See attached  ;)
Post by: Nurse Julie on October 25, 2018, 04:09:04 PM
See attached  ;)
That's what I have been looking at Paul in my manual, what route does yours take?
Post by: paul G on October 25, 2018, 04:20:27 PM
See attached  ;)
The one above in the manual  :)
Post by: Nurse Julie on October 25, 2018, 04:28:42 PM
See attached  ;)
Ok, I will re route mine then, I don't like being too different to everyone else 😂😂😂 But, it also F's my theory of why they have flat spots on No's 2 and 3. I don't think it can be just for ease of handling, it just doesn't make sense to me.
Post by: taysidedragon on October 25, 2018, 04:36:01 PM
Julie, I thought that it would be a tight bend at the bottom as well but it's not too bad. I made the mistake of fitting the breather hose after assembling nearly everything else. Getting hands in there to fit it to the plastic gizmo is a nightmare!
I thought I would have to remove a few items to make space, but I did manage it eventually, with a few skinned knuckles. The chainguard was off which helped. 🔧👍
Post by: Nurse Julie on October 25, 2018, 04:44:09 PM
Luckily, I have very small hands, just right for getting in awkward places  ;D ;D My 400/4 is off the road now for the winter so i will add that to the fettle list.
Post by: taysidedragon on October 25, 2018, 04:55:04 PM
They are 2 types. One is marked 1 and 4, the other marked 2 and 3. It depends which side you're looking at.
Post by: taysidedragon on October 25, 2018, 04:59:18 PM
So are you saying that they have both numbers on and you just turn them round to show the correct number? eg 1 and 4 are on both sides of the outer insulator
Yep. Took me ages to notice it!
Post by: Nurse Julie on October 25, 2018, 05:09:26 PM
Couple of things.
Julie your insulator picture on post 11 clearly shows that the insulator from number 2 cylinder is fitted to number 1 cylinder, sorry I just notice stuff like that.
You are correct Ken, I have also just noticed that No 4 is fitted to No.3 cylinder  :-[ :-[ :-[
Im still not understanding how only 2 part numbers covers 4 parts, or am i being thicker than normal ?
Oh, hang on, am i right in thinking then that there are numbers on the underside too then?
OK, got it, No. 3 one side, No 2 the other...No.4 one side, No.1 the other
Soooooo, mine are all on in the wrong places I guess  :'( :'( :'( :'( :'( :'(
Post by: Nurse Julie on October 25, 2018, 05:40:42 PM
I bet that when I tell Trig later about those number, he will say 'I knew that'.....no wonder he despairs with me at times  :) :) :). Its been a bad afternoon, not only are my insulators on the wrong cylinders but i routed the breather pipe the wrong way as well.......every day is a school day with these old bikes.
But, more to the point, we still haven't sussed what the indents are for.
Post by: taysidedragon on October 25, 2018, 05:41:32 PM
Oh no! I'm surprised that you could get the air box on. 😟
Post by: Nurse Julie on October 25, 2018, 05:46:19 PM
Everything fits perfectly, or i made everything fit perfectly with no problems at all  ;D ;D.
I have done over 1500 miles on her since rebuilding the engine earlier this year and she's running just fine, other than a bit of dirt in an idle jet (also on the fettle list) i wasn't planning to do much else to her this winter, now i'm going to be swapping parts around to their rightful places  :'( :'( :'(
Post by: taysidedragon on October 25, 2018, 05:49:48 PM
Ah well. Something to keep you busy through the winter months. ☺
Post by: Davelu88 on October 25, 2018, 08:38:52 PM
I couldnt see any difference in mine that are off plus if Julie has hers on wrong they still must go on ok and line up , just a thought  ;D
Post by: Deano400 on October 25, 2018, 08:46:11 PM
If I get chance tomorrow I will try Oddjob's suggestion of swapping the insulators round and fitting the carbs. It may well highlight an alignment issue although not enough to stop the carbs from being fitted. But, as the insulators are numbered and if fitted correctly, still leaves the divots on 1 and 4 a mystery.
Post by: Nurse Julie on October 25, 2018, 08:46:24 PM
I suspect Julie that the insulators are handed slightly, in that the outside/inside ones may bend very slightly inward, hence why different part numbers and why they are numbered. You may not have noticed any problems getting them engaged with the carbs as they are such a bitch to fit anyway or maybe you did notice but just thought it was normal.
Got to say I'd forgotten about the numbers on them, only really a problem if you remove them for head work etc. Of course Trig will say he knew Julie, he's a man and men don't like to admit they didn't know something even if he really didn't know.
What we need now is someone who has a 400 head off and will fit the insulators incorrectly and then correctly and post pics of them in both cases so we can see if there is an alignment issue.
I have just been given a lecture on these things and again my assumption was wrong. I thought cylinder 1 would have a rubber on with the No.1 showing uppermost, cyl 2 with a No. 2, cyl 3 with a 3 and cyl 4 with a 4. But, that may not be the case but i wont know until i actually get them in their correct 'pairs' i suppose. Trig did know, because although they are a different design, the CB750 ones are also numbered.
Post by: Deano400 on October 25, 2018, 08:49:48 PM
You are right Julie.
No. 1 will have 1 at the top 4 at the bottom.
No. 2 will have 2 at the top 3 at the bottom.
No. 3 will have 3 at the top 2 at the bottom.
No. 4 will have 4 at the top 1 at the bottom.
Post by: Davelu88 on October 25, 2018, 08:57:42 PM
Anyone know what the divots are for ;D ;D ;D ;D ;D ;D
Post by: Deano400 on October 25, 2018, 09:05:18 PM
Nope. Still waiting, but seems an odd one as there is no obvious answer.
Post by: Athame57 on October 25, 2018, 09:23:58 PM
I reckon some slitty eyed git on the assembly line damaged the mould and then filed these little grooves in to cover it up and hope people will think that's the way it's meant to be!
Post by: Deano400 on October 26, 2018, 11:18:29 AM
I've had a look at the insulators and carbs this morning.
The head inlets are all in line, the insulators are all in line and the carbs are all in line. So the insulators are the same length and not angled.
However measuring the head, the centres between the inlets are different. Between 1 and 2 the centres are approx. 65mm, the same for 3 and 4. The centres between 2 and 3 are approx. 70mm, this is because the cam chain runs between 3 and 4. The centres on the carbs are all the same, approx 67mm.
So the insulators have to be in the right place and the right way up because they have a dogleg. Easy to see on number 2 and 3 when you look for it.
Installed with 1, 2, 3 and 4 at the top (left to right) the carbs line up with the insulators.
Installed incorrectly would definitely make it more difficult to mount the carbs. I guess also would greatly increase the risk of air leakage and poor running.
Typo, the cam chain runs between 2 and 3.
Post by: Deano400 on October 26, 2018, 11:19:32 AM
Still don't get the divots though. :(
Post by: Nurse Julie on October 26, 2018, 11:59:09 AM
We'll done John. I will re arrange mine to fit in their correct places. I had no more trouble than usual fitting my carbs back on, they are always a bit of a bugger so no difference noticed when I did it although I had fitted the insulators in the incorrect places.
Post by: Nurse Julie on October 26, 2018, 06:47:04 PM
Haha Ken, it doesn't really work like that in this house. I have to learn by my mistakes, the only advice Graham will give me is after I have cocked up and his usual statement is 'if you did it right in the first place, you wouldn't have to be doing it again'. Most helpful.....NOT 😀😀
Post by: Nurse Julie on October 27, 2018, 08:41:02 AM
In that case Julie wash his pants with a load of HIS £20 and £50 notes in them, see if he's willing to let you learn by your mistakes in that case  ;D ;D
😁😁😁😁😁 I will report back Ken.
Post by: allankelly1 on August 13, 2020, 06:36:45 PM
Post by: Bryanj on August 13, 2020, 08:10:13 PM
Wghats a 20 or 50 £ note?
