SOHC.co.uk Forums => CB500/550 => Topic started by: Davelu88 on February 03, 2019, 05:47:50 PM
Hi all, anyone know how much fork oil should be in a 550K1 and what oil to use , searching brings up varying opinions.
Assuming it's the same as the 500.
Try 160cc atf oil
Cheers John
[attachimg=1]
Or ATF
Sorry to correct you John, it is 164.997 cc :o and that is on a full strip and clean. If just a drain from the side bolt then totally different ;D ;D
Just a drain & replace Graham , so what would that be. cheers
It is very hard to get it correct with a drain. You can be out by 10cc on each fork but, the book says 135 to 145cc ;)
My CB500K2 (ED) has the same legs. I personally have best results with 140cc 7,5 weight.
Cheers ;D
