SOHC.co.uk Forums => CB750 => Topic started by: Andrew-S on February 20, 2019, 12:27:35 PM
Title: K1 Headlight Ears Removal
Post by: Andrew-S on February 20, 2019, 12:27:35 PM
Hi Folks,
I'm looking at the best way to remove the K1's headlight ears and bowl for painting - I've seen threads where the forks have been removed but wondered whether removing the upper triple clamp is an alternative method.
Grateful for advice.
Andrew
Title: Re: K1 Headlight Ears Removal
Post by: Green1 on February 20, 2019, 06:00:07 PM
Four bolts and remove speedo cable and the forks are out.
Good excuse to give it all a  good clean at the same time then
Post by: Andrew-S on February 21, 2019, 08:05:25 AM
Thanks for the advice, off with the forks it is then - that'll definitely be a winter job!
Andrew
