SOHC.co.uk Forums => Project Board => Topic started by: captaink on January 10, 2016, 05:46:08 AM
Hi all,
Having recently acquired a complete GL1000 fork assembly for fitting to my CB750 frame.
Rather than using the original fork top which will require major surgery to look good I was looking for a better looking billet one.
Any suppliers of these in the UK. ? or have I got to look in the USA ?
Any assistance appreciated
Also on stripping the forks an ally sleeve, correct part name oil lock piece was missing... has anyone got one spare ?
I would also want to replace the fork top nuts for something better looking ,any suggestions ?
Regards
Keith
Hi Keith,
Just looking at my Haynes manual for 75 to 79 GL1000, I can't see a part labelled 'oil lock' but being a Haynes that doesn't mean anything! Are you referring to the alloy sleeve with a taper at one end that the damper tube fits into? Can you take a pic of tother one as I have a suspicion it's fitted to other forks too, including 350 and 400 fours. I certainly have a spare for those if they are the same size. Alternatively I could knock one up on the lathe if you supply accurate dimensions.
Ian
Just found the part in the 400/4 parts list described correctly, unlike Haynes, as 'piece, oil lock' with part number
51432-369-000. Is that your part number?
Checked my early 350/4 parts list and they are a different setup, apologies to anyone if I misled you by saying 350 and 400 are the same - they ain't.
Ian
Just found your part number for GL1000
51432-371-003
So they are different size but similar in appearance
You could try this guy on .net in the US: http://forums.sohc4.net/index.php/topic,150982.0.html
Steve
I have seen some billet yokes on eBay that some one makes in UK .steering stem nuts there's ttr 400 that does them he's a member on here . 15 dollars and he does some nice preload adjusters for forks that look good .he does have a web site don't no if you have seen it .
If you have to buy in US dime city do them I've ordered off them .there good to deal with
If he's still going then Malcolm Sheperdson @ Malarkey engineering in Bishops Castle was making billet yokes back when I did work expirience there.
