SOHC.co.uk Forums => CB350/400 => Topic started by: Greg65 on October 22, 2014, 11:04:59 PM
I am replacing the seals on the front forks. The first one has come apart fine however ( there is always a however) the second is sulking. The bottom socket bolt, oil lock piece and under seat pipe are all rotating! So how do I hold the internal gubbins still while I undo the socket bolt. Thanks in advance for your wise words.
Greg
Put the fork back together with spring and top nut the hold fork upside down and push down on slider to compress spring
Second that... you need friction to hold the inner damper rod still.
or use the speed of an air gun that worked on mine
Sharpen a broom handle like a pensil and bang it in with a hammer can work too.
the way I got mine off was wrap fork in a towel put it in a workmate or the like and use an allen key on a socket,
one like this
http://www.ebay.co.uk/itm/Signet-6mm-Allan-key-socket-3-8-drive-/251681322950?pt=LH_DefaultDomain_3&hash=item3a996037c6
did not use a lot of pressure , more of a snap action to break the seal
Thanks for all the advice. First up tried the reassembly and spring compression method, no joy. So picked up the offending fork and walked down the road to my local garage. Air gun worked a treat. If I had known would have gone there with both in the first place.
Now a quick question for the assembly. The workshop manual mentions a " liquid sealant" on the threads of the socket bolt prior to assembling. Any particular type?
Cheers,
Greg
Hi Greg,
I'm surprised they say use a sealant. I never have. there should be a copper washer under each Allen bolt. This should seal fine. You could use some of the dreaded silicone gasket but just a smear. I wouldn't use locktight and you will have trouble getting them apart again should you or anyone else ever need to.
I have seen threadlock mentioned in the cycleserve manual, presumably to prevent the bolt working loose in service, think about it, if the bolt came loose, what is holding your fork leg together, frankly, nothing. I bought a pair of n.o.s. fork legs from D.S.S. About 20 odd years ago, and one of the seals leaked, so took them apart to renew them, and there was some kind of sealant/thread locking compound on the factiry fitted bolts. So I used some loctite thread lock on rebuilding, and had no problems dismantling them to do the seals again 10 years ago. It's up to you, but I would certainly go for a thread locking compound.:))
Sent from my GT-S5839i using Tapatalk 2
There was some sort of sealant/thread lock present around the lock bolt when I dismantled them. I have heat treated the copper washers so will see how that goes.
Your bike, your choice, but if Honda specify sealant/locking compound, they do it for a reason!???
Done loads, never ever used threadlock but sometimes new washers
Same as Bryan, done shed loads over the years. Seen them with & without thread lock but, always build without.
However. Always torque to specified torque.
As the forks are penciled in for a rechrome and grind in the near future I will leave it out. Many thanks for all the wise words.
Greg
"I have seen threadlock mentioned in the cycleserve manual, presumably to prevent the bolt working loose in service, think about it, if the bolt came loose, what is holding your fork leg together, frankly, nothing."
Is this correct?.... is it not a fail-safe design, it the bolt cannot unwind appreciably due axle clamped over it?
Upto this point had always figured the seal was the job of the (serviceable) copper washer. But agree, if Soichiro Honda says 'use it'....!
Since the forks are generally under compression ( unless anyone jumps their sohc honda ) then the bolt is hardly going to cause the forks to disintegrate in service if it comes out. Far more worrying would be a load of fork oil dumping itself potentially onto the front tyre if the bolt works loose, that said I don't think I threadlocked when doing fork rebuilds though I don't do that many so would probably be following a manual, cirtainly was on last rebuild of forks, but cannot remember if it specified thread locking compound. I prefer to use the honda dealer workshop manuals to haynes where available.
