SOHC.co.uk Forums => CB500/550 => Topic started by: petermigreen on October 24, 2017, 08:22:21 PM
I know they are different part numbers but can anybody advise if the 500 starter solenoid is the same or more heavy duty than a 400 one. Or are they interchangeable?
Voltage regulators, same question?
Thanks, Peter.
You won't have a problem interchanging starter solenoids. The original electromagnetic regulator may not interchange though or if it does it may need tweaking.
Thank you
Connectors on reg point a different way otherwise same
Thank you
