SOHC.co.uk Forums => CB750 => Topic started by: jfetsko on August 12, 2005, 07:22:01 PM
The starter button on my
G'Day Joe, Had exactly the same problem with my 1972 , the one with the noisy clutch. I sprayed some WD40 into switch and button area and it fixed my problem. Also made switch smooth to operate. I sprayed the other side switch as well, noted differance straight away
Cheers Paul
