Other Stuff => Desperately Seeking!! => Topic started by: juitz on April 13, 2023, 08:34:26 PM
Anyone know where I can get the 7mm thrust washer on tacho pickup? P/n 90451-292-000
Or know dimensions for equivalent replacement?
7mm thrust washers are available, but don't know if they are correct dims, o/d probably to big for a start.
https://simplybearings.co.uk/shop/Engineering-Parts-Washers-Spring-Steel-Thrust-Washers/c4713_7364_7506/index.html?page=4&selection=Needle+Roller+Thrust+Bearing+Washers&gclid=EAIaIQobChMIyMjW7fmp_gIVz9vtCh0uGgA0EAAYASAAEgKJ-_D_BwE
You need to select 7mm on drop down.
